Question about Refrigerators
Frigidaire Actuator model glhs68egpb1
Hello, you helped me with replcing the water actuator in the above product, It worked, but when putting everything back together, I reconnect the face panel and none of the lights light up or neither actuator works now. When putting the face plate back together, I know that by accident, the white flat wire from the motherboard connecting to the actual faceplate was disconnected. I replaced it and put it back lining the contacts up to where I believe they were connected...could there have been something else inside that I could have messed up or disconnected to cause it to not work at all now? Please help! Thanks!
  • j42noto Jan 06, 2009
    It worked---thank you!
  • Refrigerators Master
  • 2,651 Answers
That awaur is definalty apain in the rear to reconnect, i would first see that the wire is in correctly( should fold along normal lines to get proper orentation)check both end of connection, remove power first, so as not to blowe any circuitry,a small pieceof masking tape should hold the wire at either end to teh facade so as to minimalize the stress/flexing of ribbon wire. be sure to check the up[per wire harnesssa s well, perhaps you disconnected and never re attached
Posted on Jan 06, 2009
Auger control rod will not engage with actuator on ice bucket correctly. I have to keep manually moving the rod with my hand. When bucket is removed the actuator seems to operate fine.
Hello friend, thank you for your submission!
From what you have described the auger on your Frigidaire refrigerator is not operating properly when the ice bucket is installed. This could be a possible issue within the ice bucket or motor of the refrigerator. I would be happy to help look up any additional information with the use of your model number. You can locate the model number on your serial tag which is in the fresh food section. Once I have that information I would be happy to assist you further. -Matt
Mar 17, 2016 | Frigidaire Refrigerators
The automatic door lock for the passenger side of my 2005 Corolla no longer works. I can't find out how to fix it. Is it simply an actuator, or is it something else?
More than likely an actuator...just replced the one in my pathfinder. Easy to remove and replace.....check your fuses first though. If you have a bad actuator and need help on the procedures, just reply to this post and I will get a notification through my email. Swap the actuator with one from the drivers door. You should know if you actuator is bad. Another thing it might be also is that there is a little plastic "pin" that pops the lock up. If it is broken off, you need to replace the little piece. Take a look at it and you will see what I mean.
Aug 25, 2009 | 2005 Toyota Corolla
Which breaker should I replce to make my rear hatch actuator work ona 2006 GMC Yukon? The actuator clicks so I know its trying to get voltage and cannot
I had vehicles that sound like this at the dealership,pull off back panel to look at the actuator sometimes they but are not strong enough anymore to move the rods and I also had some that the plastic end broke.
Aug 20, 2009 | GMC Yukon Cars & Trucks
Need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea
click on link below
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
Changing out actuator
If you are speaking of the water dispenser actuator the parts ar removed from front of the dispenser control panel. Visit my site and enter model FRS26TS7DB5 into the model search feature. once there look on left of screen and choose photo # 15 it shows a breakdown of the parts. We also offer free help and assistance. Click link below, Thanks Sea Breeze
Replace water actuator
im assuming you replaced the water actuator,and now cant fit the water hose back into the holder??? try disconnecting the hose under the freezer door hinge, this will allow you to pull extra hose up into the dispenser area, then after remounting the face you can reconnect at the bottom
Nov 25, 2008 | Frigidaire FRS26R4A Side by Side...
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
