Question about iRiver T10 MP3 Player
IRiver T10 512 MB USB Freeze
My player is having trouble connecting to my computer (PC). It works fine when it is not plugged in, but if I try to connect it through the usb cable - in order to transfer files it freezes up - and sometimes freezes my computer as well. When I plug it in, the computer instantly recognizes it - and if I click "explore folders" it will open the iriver T10 folder and inside that is a folder called "Fat 16 system" I don't remember that folder being there before I had this problem. It is the only folder in the T10 folder - if you click on that the computer searches forever and never finds anything inside it. The whole time the iriver screen reads the normal "USB Connect" as if it were working fine. (I have tried it on two different computers and the same thing happened on both so I know it is the player and not the computer) I love this player - is there anything I can do to get it to work again? would deleting the Fat 16 system folder work or would that make it unusable? Should I reformat? I do have some recording on the player I would rather no loose but I can't really do anything when them at this point.
  • 2 more comments
  • Cacophony Nov 29, 2007
    i have the exact same problem and this solution doesnt help at all. on the iriver offical website it says he and i should have 2 folders (Data and Media) not the fat16 system
  • el21lflttle Dec 11, 2007
    I am also having the same problem. My T10 used to work fine with other pcs, but once I tried with a new laptop I got the FAT16 folder as well. Cant format it and when I try to update the firmware with the updater from the iriver site, the device freezes on 'transferring data' and will not complete the update. I am still trying, please help if possible.
  • DADEAE Nov 27, 2008
    I have the same problem. Everyone (including iRiver support) keeps re-explaining how it SHOULD work. Well folks, it is not working like it SHOULD.
    The one guy who said that something worked for him was actually having a different problem. I have also tried his suggestion about the firmware upgrade option in settings, but I get a "file error" that there has been no firmware added to the device... which is obvious, because the whole point is that windows can't seem to access the device as a valid file system, and iRiver's firmware update software can't recognize the player, either.
  • Anonymous Jan 13, 2009
    SAME HERE.
    Scholar:
  • 67 Answers
Try to re-format it. on player go to settings, then advanced then format. select format, say yes and it should reboot. if that doesn't work you need to upgrade the firmware. got to iriveramerica.com, support, ultra portabale support and download firmware updater software. Not a bad idea to upgrade firmware in either case. Your music will be lost when you format but you can simply re-load it from your music manager on your PC.
Posted on Jul 29, 2007
  • jim fitterer
    jim fitterer Dec 14, 2007
    Well ya know...... all I can do is offer suggestions. If it doesn't work you don't need to label my suggestion as inappropriate. I'm not under any obligation to help you other than that I'm a nice guy...........
    Here's another suggestion tho. Might work, might not.
    With player NOT connected to computer..........
    Right click on my computer. properties. device manager. look in the list for hard drives and or devices for the T10. Might be under USB or mass storage listing. If you find it, right click and select remove this device.
    Once this is done, reboot computer, then connect player and see if it's recognized.
    Another possibility.... if you can right click on the FAT16 folder then you should be able to format it. That might also sove the problem.
    Good luck.
First you check what kind of rollup you have installed on your computer. If the roll up is for the window media player 11 which roll up 2, delete it on control panel. >control panel>add or remove>find the file and delete it. After this you reboot the computer. After the reboot, you connect the player. Now it is able to be accessed with no difficulties. After this install new firmware
Posted on Apr 21, 2008
Ok! I got it. Mine was freezing too when doing the firmware update, kept saying it could not copy files over. I then disconnected it, went to Menu/Settings/FW Upgrade. It asked if I wanted to upgrade and I hit yes. It did its thing. Not knowing if it upgraded anything I performed the Firmware update program again, I couldnt believe it when it said the it was updated with latest update did I want to reinstall. Canceled out of the firmware update and started up my Windows media player (I have version 11) and it worked! Created playlists-synced-erased and copied other playlists. Hope this helps
Posted on Feb 02, 2008
SOURCE:
Iriver Clix 2 8GB connecting to PC problem
Usually it have to, but if is not use iriver plus software !! or see if u have drivers properly installed.
Apr 28, 2009 | iRiver Clix Digital Media Player
My iriver plus3 software does not detect my iriver h10 player
GUYS ALL YOU HAVE TO DO IS PUSH THE USB CABLE HARDER INTO THE DEVICE. IM A GENIUS!!
Oct 15, 2008 | iRiver H10 MP3 Player
Iriver e100 doesn't communicate properly
umm.. this is what i did to solve this problem. i hooked it in the back usb port then put the iriver disk in then went to start control panel printers and other hardware the on the left side add hardware the i found it on the list and instaled after that you have to use windows meda player to add music and it works just fine .
May 20, 2008 | iRiver E100 Digital Media Player
No longer seen by any computer
For me, having upgraded Windows Media Player to version 11 caused the problem you are experiencing. Find a computer with Windows Media Player Version 10, then use iRiver's firmware update tool to install new firmware (version 1.77), then your T10 will work fine even with Media Player Version 11.
May 12, 2008 | iRiver T10 MP3 Player
Iriver H320
there is a setting somewhere that stops it charging when you connect it to a usb port on the computer.
May 08, 2008 | iRiver H320 MP3 Player
Iriver Clix USB freeze
My screen also froze in the music menu, but when I connected to the PC, it was recognised and I could get into the files. Try resetting it by sticking a paper clip in the reset hole if you've not done it already. Mine's working fine so far....
Feb 17, 2008 | iRiver Clix Digital Media Player
Cannot transfer files
go to http://www.iriver.com/support/down_view.asp?searchProductIdx=73&searchCategoryIdx=1&searchString=new+firmware&page=1&idx=844&tmpSearchProductIdx=&tmpSearchCategoryIdx=&tmpSearchString=
download the updater. unzip the file and run the installation program. after you have install the iriver firmware updater, run the program. it will automatically detect what you need. follow the instructions. if the updater stops at 50% don't worry. wait bout a min or 2 then unplug your T30 and it will update by itself
Dec 07, 2007 | iRiver T30 MP3 Player
I plugged the USB cable into it and suddenly it now won't turn on at all
totally the same problem here and i still dont know what to do and from what i here, iriver support does nothing for you because it's a "known" problem
Oct 30, 2007 | iRiver T30 MP3 Player
Iriver T10
Somehow the driver went missing. Click on "My Computer" and then click "view system information," then "hardware," then "device manager," then click on iRiver (it'll be there even without the driver) and then it will give you a yes/no option to look for driver software. Obviously, click "yes" but notice that you are also cued to put in a CD "if you have one." I still had the CD. It will search both the CD and online for a driver, but the computer found the driver software on the CD. Make sure you only put the CD in when cued to do so. If you don't have the CD, then contact iRiver about getting a driver download or having them send you a copy of the CD.
Mar 12, 2007 | iRiver T10 MP3 Player
IRiver MP3 Player Not Inisializing
If you haven't already I would try an emergency connect. -First perform a standard reset as you did before (press rear button for 20GB or disconnect & reconnect the battery for the 5/6GB versions). -Leave the unit turned off, but connect it to your computer's USB port. -Hold down the "o" button and then press the power button for a second to power on the device. -Do not release the "o" button until you see a message such as "emergency connect" or "mass storage" on the player screen. I beleive the message has changed with firmware versions, but it should be something similar. -If this works it should be detected by your computer as an external drive. You should have access to the files. -I would remove all music files from the device and then use the iriver plus software to restore system files. -If you manage to get to this point I would install the newest firmware available for your model of H10, found at the iriver site. The newest firmware adds a lot of functionality, speeds up player response significantly, and fixes many bugs as well.
Dec 03, 2006 | iRiver H10 MP3 Player
iRiver T10 MP3 Player Logo
841 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
