Continuation!!!problem i tried to connect it before here on my computer and it works it appear on My Computer but then when i try again to add now it doestn recognized anaymore....no I havent tried to connect with other computer.....
  • 345 Answers
As strange as it may seem, i have seen USB devices work one time and then be dead the next time you plug it in. I would try to connect it to another computer Or another USB plug on your current computer. If that doesn't work, You might try removing the driver for this device (if it has a driver for your MP3 player) and reinstall it. If when you connected it the first time the computer did not ask you to install a driver then the operating system already has the driver installed for your device.
Good Luck!
Posted on Jan 06, 2009
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
Got a new Iphone 3Gs and all seems to be ok but when I connect it to my pc all I get is a "iTunes cannot connect to this iPhone because of an unknown error". I'm hoping its something simple that I've just...
If your using a MAC try the below steps as this worked for me:
1. User - Library - Prefrences - com.apple.iTunes.plist
2. Delete that com.apple.iTunes.plist
3. Restart the computer. It should recognise.
If your using a PC the steps are lengthy, and the steps are:
Restore I-Phone
1) Close all programs and restart computer.
2) Open iTunes and plug in powered off iPhone with direct USB connection.
3) If iTunes fails to connect to iPhone...continue to #4, if it does...restore.
4) Shut DOWN iTunes again.
5) Power OFF the iPhone & Disconnect from computer. (Power off two ways-one will work, hold home and sleep button until off or just hold sleep button until off)
6) Hold down Home button & connect to computer using direct connected USB cable (keep holding down the home button until iTunes sees it).
7) It should go into recovery mode and iTunes should recognise it.
8) If you want to recover to previous software version, Hold Alt/Shift and click restore in iTunes. Then select the old update version.
If the above steps doesnot work then try the below steps:
1. Turn the iPhone ON
2. CONNECT it to the computer with a DIRECT USB connection.
3. Make sure iTunes is open so you'll know when it enters DFU mode.
4. HOLD the Power/Sleep-Wake button AND the Home button for 10 seconds.
5. RELEASE only the Power/Sleep-Wake button and continue to hold the Home button.
6. WAIT until iTunes recognizes the phone in DFU Restore mode (in Windows a bubble pops up saying it recognized new hardware "DFU Mode" or something to that effect)
The last step may take SOME TIME, like, say, even 60 seconds or so.
The screen should be OFF (black), if you see the "Connect to iTunes" logo, START OVER.
It may take a few tries to do the steps just right, just reboot
(hold both Power/Sleep-Wake AND Home until the Apple logo appears and the phone turns back on) then try again.
7. Then restore the iphone
-Plug one end of the cord into your phone and the other in your computer
-Remove the cord in your computer, leaving the cord in the phone still plugged in
-Hold both the home button and on/off button on the phone
-Once the screen turns off, let go of the on/off button but continue holding the home button
-Plug in the other end of the cord in your computer while still holding the home button on the phone
-Once the apple logo appears, continue holding until you see the plug into itunes screen on your phone
-Click restore.
Hope this should resolve your issue :)
Mar 01, 2010 | Apple iPhone Smartphone
Printer will not print from computer .printer is on and appears to be connectes to computer.
try replugging the printer into the computer - do you hear a sound indicating it's being connected? Try a different port on your computer as well. Also try powering off both the printer and pc and trying again - if it still doesn't work, click on start, go to printers/faxes, and make sure your printer is showing up in the list - if not, then click on add printer, and go through the add printer wizard to readd the printer to the computer. Hope this helps! Good luck!
Sep 12, 2009 | HP Pavilion dv6000z Notebook
I am unable to login our domain user account.
This is usually a computer trust issue, if the computer was previously used to logon to the network and has been rebuilt or had in problems it can have trust issues. First way would be to change the computer name and add the DNS Prefix for your domain. ex desktop.abc.com to desktop1.abc.com. when prompted it is best to use the domain admin or equivalent to make the change and then reboot.
Jan 28, 2009 | Microsoft Windows Server Standard 2003 for...
My Computer and iTunes does not recognize my iPod
Try connecting this ipod to rear USB port on your desktop computer and then try this out
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
It should work fine
Nov 26, 2008 | Apple iPod MA446LL/A MP3 Player
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click OK.
Step two: - Check the product cable
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
If the menu includes Use Printer Online , click that option.
Step four: - Stop the print queue
Double-click Macintosh HD.
Open the Print Setup Utility folder.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
Step six: - Remove and re-add the product to the printer list
Click the red X to delete the product from the computer.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
