Question about Yamaha HTR-6130 Receiver
Yamaha HTR-6130 firmware
I saw 2 of your posts that mention a firmware update for HTR-6130. Yamaha support told me there is no update but I think they are incorrect. Do you know which is the latest version? Mine says D017. I have the service manual and can update it but can't find the firmware anywhere. Is there anywhere it can be downloaded? Thanks
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Posted on Feb 16, 2009
mlapres
  • 757 Answers
SOURCE: yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Posted on May 08, 2009
smarthome2
  • 1114 Answers
SOURCE: trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
Posted on May 24, 2009
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
Need HTR-6130 Manual.
The manual is available as a pdf file from yamaha directly at http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-6130_black__u/?mode=model
Midway down under the "support" tab.
May 29, 2011 | Yamaha HTR-6130 Receiver
How do I properly wire 2 6ohm bose 201v speakers and 1 sub to a yamaha HTR-6130 amp
According to each product's manual.
Bose.com for the 201's.
Register and download the HTR manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
SUB???
May 15, 2011 | Audio Players & Recorders
Receiver displays Dolby Digital while watching TV, but only 2 front speakers work. This is the case on only certain TV stations. I have a Yamaha HTR-6130
Depending upon transmmission bit rate, if the transmission is > then 6130 bit rate it will automatically change to 'STRAIGHT' mode and in this mode only two front speaker will work.
Oct 15, 2009 | Yamaha HTR-6130 Receiver
All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Jul 04, 2009 | Yamaha HTR-6130 Receiver
Cable company remote cannot find Yamaha HTR-6130
Dec 28, 2008 | Yamaha HTR-6130 Receiver
No audio comes from the rear right speaker. what am i doing wrong with connecting the speaker on the htr-6130?
Swap the rear right speaker to rear left make sure the speakers and speakers wire are OK
Initializer the unit as follow set the unit in STBY mode if you are not sure which mode turn off the unit with the remote control now the unit is in STBY mode. Pressing STRAIGHT and AUDIO SELECT keys simultaneously then press power STBY button on front panel the display will show 1: Analog ByPass use the PROGRAM knob to move up to 13 PRESET INHI then press 1 or 2 keys to change to PRESET RSRV then turn off power now unit reset to factory just turn on and try it
Let me know how do you go
Cheers
PS: this model have an update firmware if your is still under warranty bring it back to Yamaha or 1 of the service center Yamaha they are able to update for you. Due to confidence I can not post that firmware sorry for that inconvenience
Nov 28, 2008 | Yamaha HTR-6130 Receiver
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
181 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
