Question about Mitsubishi XL8U Multimedia Projector
Yelloy spot I have three Mitsubishi xl8u projectors doing the same thing. Each has a random shaped yellow spot in the middle of the display. I think the prism block needs replacing but I can?t find replacement parts are a repair shop to that will take it in...are these projectors worth fixing
  • dloseke Mar 10, 2009
    Same issue here...it seems that the yellow blog changes somewhat between each power off and power on. Prior to this issue, we had an issue where the whole screen had a strong yellow tint.
  • 32 Answers
Yellowish colorization on center of displays is not a prizm issue. It is generally a need of cleaning factor. Even with the filters clean, the LCD's can and acquire heavy dust build up on the panels. This is not limited only to the LCD's it also applies to the polarizers and spectrum filters. Your unit most likely requires deep lens and panel cleaning. This is done by trained professionals, as they can be permanently damaged if the proper tools are not used.
Posted on Jul 10, 2009
  • 22 Answers
Depending on what it is if it looke like a scorch mark the it is not the Optical Engine (prism) it is more likely to be the polerising filter most are quite esly changed and would cost about £15 ($30) for parts and about twice that to get them fitted at a service center, if it is pixel dots then it is a LCD replacement and not worth doing.
Marc Engineer
Posted on Jun 17, 2009
    Champion:
  • 205 Answers
Your blue device is dying, this problem is as old as lcd projectors. I would suggest replaceing with a dlp product. Lcd's are organic and can't handle the heat and the blue is the first to go. Average about 3-4000 hours..
Posted on Jul 07, 2009
Yes, i have the same problem for 2 lcd projector ex: TLP-T61M.
Do you have a site to purchase this parts ?
Posted on Aug 02, 2009
    Problem Solver:
  • 6 Answers
There is a two problem, one if any lamp problem or color filter, Just check between the LCD panel and lens thin film will be there that you need to replace.
Regards,
prakasam
Posted on Jul 08, 2009
Hi, how do i reset lamp timer on Mitsubishi XL8U?
Reset of the lamp operation time:
Plug in the power cord, turn on the
lamp, and reset the lamp operation time by keep
pressing the <, >,buttons and POWER buttons on the
control panel at the same time about three seconds.
http://www.projectorcentral.com/pdf/projector_manual_2249.pdf
May 22, 2014 | Mitsubishi XL8U Multimedia Projector
Why is the Status Light on my Mitsubishi XL8U flashing red? My projector is still working but the status light flashes red.
With out knowing the state of the power LED, my best guess is the Status light is solid red and telling you to purchase a replacement lamp before the current one dies. Attached is a chart that will show you the errors possible depending on the LED statuses:
Mar 11, 2011 | Mitsubishi Lamp For Mitsubishi XL8U...
Projector is working but intensity problem,, display is not good
Have you changed the brightness setting or put the projector into eco mode. ?
Also see what mode your dvd player is in (same on projector) they can have film modes which reduce the brightness.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Mitsubishi XL8U Multimedia Projector
2 red lights on, no blinking. And no bulb on is the bulb burned out?
i think ur sytem in stand by mode / pcb complaint related to microcontroller.
May 27, 2009 | Mitsubishi XL8U Multimedia Projector
Mitsubisi XL8U
The XL8U will tell you when the lamp needs replacement. There is a yellow box that will appear telling you so. The lamp is easy to replace, the model number is VLT-XL8LP.
Mar 18, 2009 | Mitsubishi XL8U Multimedia Projector
Yellow spot
the problem is in the light path starting with the blue input polarizer then the blue lcd hopefully its just the input polarizer. worst case you will have to replace the LCD block witch is expensive to do. the polarizer ia a speacialy tinted glass designed to help with the LCD's temp.
Oct 23, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
May 20, 2008 | Mitsubishi XL8U Multimedia Projector
go to menu and press it---press right or left arrow button and go to installation press enter.
--go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
Mar 15, 2008 | Mitsubishi XL8U Multimedia Projector
Mitsubishi XL8U Multimedia Projector Logo
774 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
