Question about Casio Office Equipment & Supplies
XJ-S30 when powered on the lamp does not comes on
When power button pressed on the temp/Auto lights comes on amber but the lamp is not turned on.
Replaced the bulb.
Posted on Jan 06, 2009
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Casio xj-s41 lamp and temp light amber blinking
FIRST LOCALIZE THE UP/ DOWN/ LEFT/ RIGHT AND MIDLE BUTON- ON FUNCTION CONTROL
OK...
KEEP PRESSD FOR 10 SEC
INPUT / MIDLE BUTTON FROM FUNCTIONS/ AND RIGHT ARROW
RELEASE THOSE BUTTONS
NOW YOU SHULD GET THE ERROR RESETED.
NOW YOU HAVE TO INITIALIZE THE UNIT:
POWER OFF UNIT( FROM POWER BUTTON)
POWER ON
PRESS AGAIN: INPUT/ MIDLE BUTON/ RIGHT AROW TILL SHOWS A SERVICE MENU ON SCREEN
CHOSE INITIALIZING AND RESEAT UNIT.
GOOD LUCK...GO CANUCKS
Nov 30, 2010 | Casio XJ-S41 SuperSlim DataProjector ...
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
Projector problem HELP!? my projector was on whiles the utility power went out, and when the power came back i realised it had affected my projector, when i put it on (press the power button) the:...
it wasn't able to go through the cooldown mode. turn it on and power down, letting it go through the cooldown mode. does the lamp come on at all?
Jan 22, 2009 | Casio XJ-S31 Projector
HOW TO RESET LAMP HOURS
Do this
Unplug the AC cord
Press Input, VOL - /Standby/Menu at the same time.
Plug the AC cord and wait until the Power light is amber. release the Vol/Standby/Menu bottoms. I hope will work for you.
Jul 12, 2008 | Toshiba TLP S30 Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
291 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
