Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
I've lost my manual and video need threading info
I need to make sure I'm threading right because my lower looper keeps breaking. Is there anywhere thats has the threading guide? I know the order but need to make sure I'm starting it right at the top. Thanks
I had the same problem. I found if you turn the wheel three times and then put in material, it will work fine. If you try to run a long thread to see if it works, the lower looper will break. Try it with material and it will work fine.
Posted on Aug 15, 2007
    Problem Solver:
  • 5 Answers
Www.whitesewing.com try ther web site
Posted on May 29, 2007
Upper looper thread keeps breaking
try a new needles
check for burrs
make sure the thread is not caught anywhere
Feb 04, 2016 | Sewing Machines
How do I thread my overlocker
If thread is breaking, it usually means it is threaded incorrectly--either you have missed a thread guide or have it looped somewhere it shouldn't be. The tension could also be too tight on that one thread.
RAISE the presser foot BEFORE threading!
Be sure you are threading each thread in the ORDER described in the owner's manual. Most machines are threaded in this order: 2nd thread from the right (upper looper), last thread on right (lower looper (this thread must cross over the top of the upper looper in the final step!!!), then the needles--but you must check your machine's manual for the correct order!
Confirm with your owner's manual that you are threading all the guides. If you miss one of the thread guides, your machine will most likely not operate.
Also, if you break a thread, it is strongly recommended that you remove ALL the threads and start over from the beginning. Sergers can be very finicky!
This video may help, although your machine may thread differently:
How to Thread Serger Overlock Machine
Oct 28, 2015 | Sewing Machines
My lower looper thread keeps breaking. I rethread it, checked the tension and yet it still breaks.
Please re thread machine from scratch threading upper looper first then lower looper then needles also be sure needles are in with the flat back to the back of machine sequence of threading is imperative
Feb 24, 2015 | Euro-Pro Sewing Machines
Need a threading diagram for a consew694ex
I found two things for your consew, but neither of them have threading information. Generally, you thread a serger like this. Upper Looper, Lower looper, needles from right to left. If you ever break a thread... remove all other threads and begin again from the upper looper thread. (I know... it's a pain) Here's a video that is NOT your machine but explains pretty well.
http://www.youtube.com/watch?v=zt8G9kw-U_s&feature=related
I included the documents I found in case you need them.
Parts Info (keep for future reference) http://consew.marginspluslive.com/images/products/parts%20books/693ex.pdf
maintenance info (keep) http://consew.marginspluslive.com/images/products/instruction%20manuals/694.pdf
Aug 23, 2012 | Sewing Machines
Why does the 4th thread keeps breaking on my serger? I've re-threadedi it a dozen times carefully following the diagram. What am I doing wrong?
Most likely it is either your tension on thay thread being too high, or the needle is too big for the project you are working. Lower that tension, use the next size up needle, and thay should fix it. Also, I STRONGLY suggest only using maxi-locks thread. They are more expensive than other serger threads, but they are always half-price at hancock... Any other thread I have tried using causes breakage, especially on the the lower looper (the 4th thread). Although, of you keep the tension low-below 3 or so, you should be ok. If these tips don't help, I would also check your cutting width, if your machine has an adjustable one. If it is leaving too much gabric to the right of the needles, out is conceivable that this is putting too much pressure on the threads. Let me know if this helps!
Jun 23, 2011 | Simplicity Sewing Machines
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
The lower looper keeps breaking thread
Hi,...if the lower looper thread is breaking before you sew six inches or more then I suspect a threading problem.When the lower looper thread breaks, You MUST unthread the needles before you thread the lower looper. Thread the looper and then rethread the needles.
Hope that helps,
Doug
Aug 05, 2010 | Simplicity Serge Pro SW432 Mechanical...
One of the most common mistakes with overlockers is that the threads must always be threaded in order. So if you sew about 1 inch and the thread breaks try unthreading the eyes of the needles rethread the looper and then rethread the eyes of thew needles. If not you will get the same result of sewing about 1 inch and it will break again.
Aug 26, 2008 | Baby Lock Ellure
Threading the bernina 1300DC serger
These things are always complicated when you try to write them down, so I suggest a call to your local Bernina dealer to arrange a quick lesson on how to do it.
If you can go back to the dealer whence it came, so much the better..........perhaps you could go in and buy some things you need and then as you are leaving, make the enquiry with the machine in your car, they may be able to show you how to do it right away......building relationships is a very good way of feeling comfortable about asking for help.
Also..........
If the manual diagram is too small, a local library or stationery supplier should be able to magnify a photocopy for you to see it all more easily.
Jun 04, 2008 | Sewing Machines
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
154 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Oloyede Monsuru
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
