Question about Dell 962 Photo All-In-One InkJet Printer
Error light next to the on switch does not go out
I have a dell all in one printer 922 and the error light never goes out.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Dell 922 print carrier stall error message. Also, error 1200.
Hi
hope it will work
Error code: 1200
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Hope you get it to go.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 18, 2009 | Dell 922 All-In-One InkJet Printer
Dell AIO 922 printer not seeing the color cardridge
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" Click here and slecet the operating system and download the drive
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Jun 17, 2009 | Dell 922 All-In-One InkJet Printer
Error message: color cartridge missing on a Dell 922
try another cartridge. if that works then you have a bad ink cart, if not, the sensor is bad, replace the printer.
Dec 30, 2008 | Dell 922 All-In-One InkJet Printer
Dell Printer 924
I kept pressing menu, since it would not bring it up turned it off and on, it fixed itself, now it is printing.
Jul 14, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 All-in-one printer has message on printer saying head error
can you provide the error message, depending on the error and if you want to attempt to repair it yourself? Printers are like computers these days you can almost replace it for the repair cost, but if you will provide a error code we can see what we can do.
Dec 26, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 "cover open" problem / error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then close the printer after it powers on.
It worked for me.
Dec 04, 2007 | Dell 922 All-In-One InkJet Printer
Use with vista and XP
yes you need to download windows vista printer driver for dell 922 on the laptop for your desktop leave it as it is.
Get on web and search printer drivers for dell 922 windows vista install on laptop and youre done
Nov 29, 2007 | Dell 922 All-In-One InkJet Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
26 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
