Question about Zenith P60W26 60 in. HD-Ready Plasma Television
Zenith P60W26P beeps and won't turn on until next day.
This plasma screen will not show any video if it starts beeping. The unit will turn on after several hours (8+), but it won't turn on again once you turn it off. So, basically, I only get to turn it on once per day.
I am having the same problem, beeping and will not come on until the next day....did you find a solution?
Posted on Jun 03, 2010
Bose p1 turns on but only first touch works then freezes
If you've done the complete walk around i/e--unplug from wall/remove batteries takes bout 1/2-to-1 hour don't be in a hurry then go bac & reset--if no go then your room interfac M-1 needs
Apr 16, 2017 | Bose 023795 LCD Touchscreen Remote Control
My GE Microwave JES1344SK is showing the code -F3- on the digital screen and it beep three times every 30 second, the microwave won't start and any of the fuctions is working I need some help on t
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Jan 02, 2012 | GE JES1344SK Microwave Oven
Error code 04?
There is no error code 4
The unit is probably set at 4 hours operation.
To change it turn unit off then back on
Now press and hold up arrow ti'll the unit beeps
now press and hold down arrow ti'll unit beeps again
Now either quickly press the up arrow or down arrow until you get the hours of operation you desire
once you have the hours flashing simply re-peat the long holding of the up arrow ti'll it beeps and down again ti'll it beeps once the beep then the # will quit flashing wait 10 minutes or so for chlorine generator to start
Jun 17, 2011 | Intex Automatic Salt Water System for ...
My dv6-1247 cl when i turn on the power it beep 8 times and the screen does not come on help
Yu will need to determine which BIOS you have a see below
The computer beeps several times
If you hear several beeps from the PC speaker, it means that the computer failed its power-on self test (POST) because a problem was detected. The POST is a procedure that tests several components such as power, BIOS, CPU, memory, and video. Only if all those tests pass, the computer will then allow the operating system to load. But if one or more of these tests fail, beeps indicate a problem and the boot process is halted. These errors are a little more difficult to troubleshoot.
To diagnose the problem, listen to the beeps carefully and write down the sequence. Is it one long beep? Is it several short beeps? How many? Once you have the beep sequence documented, you need to find out what it means. What BIOS do you have? When you first turn on the PC, look at the top of the first screen to find out. Common BIOS types are Award, Phoenix, and AMI.
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beeps Most likely a RAM problemYou can find more detailed information about Award error messages on Award's web site.
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information 1-2-2-3 BIOS ROM Checksum 1-3-1-1 Test DRAM Refresh 1-3-1-3 Test Keyboard Controller 1-3-4-1 RAM Failure 1-3-4-3 RAM Failure 2-1-2-3 Check ROM Copyright Notice 2-2-3-1 Test for unexpected interrupts 1-3-4-3 RAM FailureYou can find more detailed information about Phoenix error messages on Phoenix's web site.
1 beep Refresh failure 2 beeps Parity error 3 beeps Base 64K memory failure 4 beeps Timer not operational 5 beeps Processor error 6 beeps 8042 - gate A20 failure 7 beeps Processor exception interrupt error 8 beeps Display memory read/write failure 9 beeps ROM checksum error 10 beeps CMOS shutdown register read/write error 11 beeps Cache memory badYou can find more detailed information about AMI error messages on AMI's web site.
If you get beep errors, you should try to think what happened right before they started. Did you add a new piece of hardware? If so, it might be faulty or not installed right. Remove it, then try again. If everything is fine without the hardware, try to reinstall and configure the hardware again. If that does not help, try exchanging it and see if that corrects the problem. If the error persists, narrow it down systematically. Remove everything but the CPU, memory, keyboard, and video card, then boot again. Does the error still occur? If not, then add one piece of hardware and try again. Repeat until one new component causes the error and you now know who the culprit is. If yes, then reseat your CPU, memory and video card and try again. If the error still happens, try replacing the CPU, video card and memory one by one to see if one of them is the troublemaker. If that does not help, you could have a bad motherboard. Check the motherboard carefully for any signs of damage. Also check for shorts, a metallic object could have found its way onto the motherboard, or the motherboard is not installed correctly and touches the case somewhere.
Page 1: Computer boot problems
Page 2: This page
Page 3: System hanging after POST
Page 4: POST running OK but Windows not starting
Good luck
Please rate FIXYA
Apr 02, 2011 | Computers & Internet
When i turn my ps3 on only a blue screen appears with no loggins also the controllers are not synching with the ps3 what do i do??!!???
Have you tried using the PS3 recovery menu. If you are not sure what this is, press and hold the power button. If the console is on it should beep once, then once again then turn off. Release the power button and then hold it again. The console will turn on, keep your finger on the button, it will beep once then beep two times quite quickly, release your finger as soon as you hear two beeps. This will now enter recovery mode. You have several options, usually restore file system or PS3 software works for most problems.
Hope this helps
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
lets try a few things bronx,
lets start by going over the beeps and lights. when you power the unit on. it should go Blue and stay blue. this means the unit is so far functioning correctly.
if your unit turns on lights up blue, then yellow , then red and stays red you have an issue
if you are experiencing the first scenario, press the power button till it goes red. which is standby mode.
then press button again till you hear two beeps, let go. make sure you have all your cables plugged in. this will send you to the diagnostic screen on the ps3 to select anyone of your options. since you are not getting a video display select the display settings and reset yours according to your type tv. if you are using a standard old school tellie, then its 480i, if you are on a plasma or lcd it would be 720p,1080i or 1080p. then you should be good from there
okay, if you are experiencing the second scenario its a much more severe issue. the GPU on the motherboard has gone bad, which is common on ps3s. if it is under warranty contact sony and they will send you out a refurb'd unit. if it is not under warranty there are a few good companies out on ebay that reflow or reball gpu chips on ps3s to repair this known issue.
since you are getting beeps and lights this is one of your scenarios. if you get no lights,no beeps then you got a bad Power Supply.
Good Luck!
Jul 19, 2009 | Sony Playstation 3 (PS3) Console
Computer turns on and beeps
Have you recently changed any hardware or BIOS settings? Is it one beep for 8 seconds or 8 beeps? If it's 8 beeps then that indicates a bad video card. If you are not using the on board video then try re-seating the video board or try a different video board.
Mar 13, 2009 | Microsoft Windows XP Professional
Plenio VXA-3000 Navigation Unit, powers on but screen stays off.
If you Need Plenio Tech Support
Dan Kim 408-970-3388 office
DVS Sales Inc.
2398 Walsh Ave.
Santa Clara, CA. 95051
posted 01.15.2009
Jun 01, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Zenith P60W26 60 in. HD-Ready Plasma Television Logo
235 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
