Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Why USB is not getting recognised
Problems related to USB
1. Your front panel USB adapter connected with motherboard through a shielded cabel which causes malfunction in data transfer as well as sensing usb drive of higher capacity. try using usb drive provided at rear usb ports this may solve your problem.
2. if not your usb ports might be disabled.check and enable it.
Posted on Jan 06, 2009
My gameon mics are not recognised when trying to play wii glee, is there a solution?
its a usb device ...get a driver ..if it has a disk that came with it ..and after that in the sound management ..look for mic..and choose from the list the usb one ..instead of the default one ...(Jack )
if the list of devices isn't available ..try in options ..
Jan 08, 2011 | Logitech Vantage USB Microphone for...
Emergency usb mode
Have you tried connecting the usb and loading an update on it at all?
Let me know if you have or if trying that doesn't work and if it doesn't then I will provide further help based on the situation
Thank you for using Fixya and Good Luck
Apr 21, 2008 | iRiver E10 Digital Media Player
My cruzer 4 mb usb stick is suddenly not recognized by the computer
this may have many causes. first possibility: the stick is dead and needs replacement. second: there may be a problem with the usb-port or -controller. if you connect a different usb device to the same port as the stick, and it's recognised, the usb- port is fine and it surely will be the stick which is broken. if the other device isn't recognised either, it's a usb related problem. in this case you should verify if all settings for usb in the BIOS are enabled, if the usb-controller in device manager has been installed supposedly. if not, reinstall, reboot and try again. if this does not work, you need to replace your computer's system board
Oct 22, 2009 | SanDisk Computers & Internet
It is not being recognised by the computer. Has a malfunction
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
May 19, 2009 | Western Digital 500GB My Book World...
HP colour laserjet 1600 not recognised by USB port
I believe the problem is related to microsoft .NET Framework. I have researched and there are many posts of incompatibility between .NET Framework and many printers not just 1600. My 1600 stopped working and I traced the problem to upgrade to .NET Framework 3.5 I uninstalled 1600, then uninstalled .NET Framework 3.5 (and 3.0 as well for good measure), reinstalled 1600 and it is working fine now again. You can uninstall .NET versions using Add/Remove programs on the Control Panel. To avoid re-updating, I also turned off Windows automatic updates. I left .NET Framework 2.0. No problems with other programs but the computer did have trouble rebooting the very first time after I uninstalled .NET Framework 3.5 and 3.0. Unknown if that was related to the uninstall or a completely unrelated problem. Anyway if you want to try something less drastic than removing .NET versions, check out this Microsoft link:
http://support.microsoft.com/kb/961118
refers to a printer fix related to .NET. In my experience, the Microsoft fixes never work but you are welcome to try before uninstalling .NET Framework versions.
Jan 16, 2009 | Office Equipment & Supplies
USB problem
Dear imyan ,
this problem is related to your operating system, here i suggest you please update the USB driver in your system or you can download it from internet.
Regards
Apr 15, 2008 | Computers & Internet
Device not being recognised - USB device not recognised...
Are you running windows media player on Vista, if so I'm having same problem. Appears one needs Windows XP, which is rather annoying..
Jan 31, 2008 | Samsung YH-925 MP3 Player
Tosh A200 Vista Home Basic doesn't recognise TZ3
I haven't been able to find the drivers etc. for the a200 for Vista, its an old camera. Still working on it, but so far, no cigar.
Jan 09, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Iomega USB 2 Desktop Hard drive not recognised by xp sp2
did you set any jumppers to slave? Is it pluged in the right spot?
Nov 24, 2007 | Iomega HDD External Desktop (32660) 80 GB...
IRiver E10 - Error screen - Emergency USB
Hi There,
There are 2 conditions related to the e10 Emergency USB message.
1. If your PC does NOT recognise the iriver as a USB device/drive, there is an issue with the Hard Drive.
2. If your PC DOES recognise the iriver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
In either case, your iriver needs to be returned to the manufacturer. If in warranty you can get this repaired at no cost (of course).
Sep 06, 2007 | iRiver E10 Digital Media Player
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
151 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
