Replace the drive belt
Maytag washer PAVT234AWW. I need to replace the drive belt on ths machine. It is a large belt that connects to 3 wheels underneath the unit. How do I do this. Thanks
  • 318 Answers
Its very simple, just put the belt around the smaller pulleys first, the pump and the motor, then turn the belt onto the transmission pulley until it "rides" up on the pulley. its not really hard but takes some practice.
be sure that you dont have a stuck pump bearing as thats what usually causes the belt to wear out.
Posted on Jan 06, 2009
How do I fix belt on my hotpoint TVM570p dryer
To do the belt. + as long as your patience lasts...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic cap on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel. To pop the belt off, turn the wheel forcing the belt to the edge of the wheel. It will eventually come off.
6. to replace belt - see motor shaft at bottom of unit. Dangle belt round shaft of motor and gently pull so it does not come off.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
Oct 14, 2012 | Dryers
Washer will no longer spin - was making loud noise then started stinking as though a belt was burning and now won't spin at all? Is there a belt I can replace?
usually when the belt burns on a maytag it's a sign that a pump, motor or trans needs replacing. tilt machine back, remove belt from underneath & ck for restrictions in all 3 pulleys. If there's a burnt belt...replacing just the belt is a waste of money
Nov 10, 2009 | Maytag HAV2360A Top Load Washer
Maytag Neptune MAH3000AWA seems to be rubbing
I suspect that you have a leveling bracket come loose. Many of the Maytag washers also use a large concrete block fastened underneath to help balance things. Look to see if yours is this type. If so then the steel rod holding thinge that holds it in place may have come loose...should be easy to put back correctly but will require some muscle. Most of the Sears Kenmore units have springs that can come loos from their connections and require re hooking but I do not think you have this type of unit for a Maytag. Hope this helped.
Aug 21, 2009 | Maytag Washing Machines
Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Jul 19, 2009 | Maytag Performa PAV2200
Problem washer will not wash or spin
If the drum does not turn by itself then there are two things which could be wrong.
1. the belt which drives the drum is broken or come off.
2. the motors brushes which wear down now need replacing.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...about half an hour...
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wma40&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
To do the brushes - about half an hour...
3. Tip the machine carefully up so you can get to the underside
4. Pull cables off the existing brushes.
5. Remove the brushes with a cross head screwdriver. Each brush as two screws holding in on, but the brushes are keyed into the motor chassis. They are fiddly.
Jul 08, 2008 | Hotpoint WMA40 Front Load Washer
Need to change tumble belt
To do the belt...
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Jun 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Waher maytag
Pull your washer forward then tilt the top backwards until it sits at about a 45 degree angle. There should be a belt and 3 pulleys underneath. Remove the belt (one of the pulleys will move to allow slack) Ignore the moving pulley and the large pulley in the center. The third pulley is your pump. Try to turn it by hand, it should move freely. Presumably, it wont and will need to be replaced.
May 26, 2008 | Amana NAV5800A Top Load Washer
Hotpoint aquarius wma50
You should be able to do both without disturbing the motor.
Mar 13, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint wd64 washer dryer
mits86 , you are correct - it could be the belt.
To do the belt...
Mar 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
350 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
