Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox 51" Model # 51MP392H/17 Color problems
Well, the first thing I had was a convergence issue. I fixed that, somewhat. I still need IC's but I got everything to line up pretty well. Now there is a haze still. I dug and dug and finally took the screen off and looked at the CRT's while the set was on (bright). I could see the picture in the Red and Green tubes but I couldn't see it in the Blue tube, which makes sense since I couldn't set the Blue to Green convergence due to no blue lines. Does this mean the Blue CRT is dead/dieing? If so, can I replace the Blue CRT with one from a 43", 50", or 63"? Are they the same size? Reason is I can get a 50" for $50 and the service manual that I downloaded is for the sizes I listed earlier which seems to work for my model.
Thanks!
  • 2 more comments
  • tkollars762 Jan 07, 2009
    Okay. Thanks. I will do that next. I am still waiting on the IC Chips and still have to take everything apart. Once I get all that done, should be this weekend, I will let everyone know what went on and any implications that came about.
  • tkollars762 Jan 21, 2009
    Awesome results! Thanks to all the posts in this forum and thanks to Merlins29 for telling me about the cleaning of the lense. I was able to get ahold of some coupling fluid and took the deltas off and cleaned the heck out of them. The blue had a slight film on it that came off with a little ethyl alcohol and a q-tip. It took about 4 hours due to the dry time of the alcohol (I was being thorough). I have to warn people that you will damage the retaining clips that hold the firing cable into the HV mechanism. I just put the cable in and the cover seemed to hold it fine.
    Well, to the point, it works great! Looks brand new now. I bought the thing for $50 and spent another $55 on parts and now I have a nice big like new TV!
    Again, thanks to you guys here on this forum!
  • MichaelECov Jan 24, 2009
    I have the same problem. Where do you buy the Convergence Kits
  • Anonymous Feb 07, 2009
    I just recently got a philips magnavox Rear Projection TV and the picture is really blurry and the color seems off. I've tried adjusting the color control on the menu, but nothing seems to help.  Is it because it needs to be cleaned? or do the bulbs need to be replaced?  Any advice is appreciated, thank you
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Magnavox 51
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your Magnavox 51" Model # 51MP392H/17 Color problems - 2c07611.png chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpgMagnavox 51
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 15, 2009
    Problem Solver:
YOU NEED TO REPLACE THE COOLANT IN THE LENSESAND CLEAN THE SMALL PICTURE TUBES AND PUT IN NEW FLUID. BE EXTREMELY CAREFUL NOT TO GET FLUID ON THE CUIRTBOARDS IT WILL FRY THEM.
Posted on Jan 07, 2009
Philips Magnavox Rear Projection 51mp392h color adjustment
Hello, below in my post is a link to the Manual library. there are detailed instructions on how to adjust the color. it takes time and some steps are difficult but using two people you should have no problem just print them out and go step by step... also I suggest doing it at night with low lights or off, and let the TV warm up for 20 mins.
Good luck, below is my general post with lots of info
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox
Need more info, does it click on and off, make any noises, was the picture going blurry, did you just move it, was in built into a wall where it wouldn't get air to cool???
Here is what I know about the 51mp392h this is a general post below I used for some other peoples fixes without more info on yours I suggest reading thru the below and links and add more info to your post so we can trouble shoot it.
51MP392H/17
What you need:
Red and green lines on picture only in the corners of the pic
YIKES, I dont know about Coolant changes but I'll post my general post about the 51MP392H/17
it has links to the SERVICE MANUALS and info to other sites that might help...
GOOD luck
General post....
51MP392H/17
What you need:
Nov 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
Have a philips magnavox 8p6044 c102
Hmmm... I dont know where to find those CTR Circuit boards I'll post my general post for you about what I know it has links to the manual and some other sites it may help.
how bad is it burned, did some chips go or just the copper circuit board tracers. you can use circuit board wire and solder it from point to point,
I had somewhat of the same problem with my IC board, I had a bad portion of the board where I had to build a new copper routing with circuit wire, the copper burned off when the resistor failed, you may need to do a little Frankenstein work on your board as a last resort... remember use a low 15 watt soldering pencil, use leaded solder, and USE flux!
however with all my work, I got it running but the IC board is still not running perfect. if you decide you cant fix the TV I would love to buy your IC convergence board from you.
GOOD LUCK! hope I helped...
GENERAL POST WITH LINKS BELOW.....
51MP392H/17
What you need:
Nov 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
No Picture No Sound Magnavox Rear Projection Television
51MP392H/17
What you need:
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 55'' Projection - Sides come in and out
sounds like Convergence issue.... I have some pictures of the bowing picture TV on the link below...
I'll post you my general message which is for a similar Philips Magnavox 51 inch TV, you'll need to check the manual verify the correct IC convergence chips and resistors, the manual link is below as well... usally the IC's are STK392-120's or 150's and the resistors are 6.8 ohm 12 of then...
anyway read the general post below it will get you headed in the right direction.
51MP392H/17
Where I got my parts that worked:
What you need:
chips
Philips rear projection tv-wont turn on
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
51MP392H/17
What you need:
Nov 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a magnavox 51mp392h rear projection tv and im having problems with the convergance
51MP392H/17
What you need:
chips
Oct 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox MDL 51mp3964h distorted and waved picutre
Hello pkrocks
It looks like your convergence amplifiers have gone bad, this is a common problem. If your set uses the STK329-110 or STK329-xxx series of amplifier both of them will have to be replaced. There is a lot of information on fixya about how to do this yourself, but you have to be careful in removing and replacing the amplifiers and the associated bias resistors.
I hope this helps
Thank you,
Shuttle83
Sep 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv has soun but no picture
51MP392H/17
What you need:
chips
Nov 05, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
756 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
