Question about Dell Inspiron 1501 Notebook
Screen is dark
With ax adapter the screen /dell inspirion 1501/ is dark. i can't see if the os is loaded or not. With the batery alone i see the screen but it askes me if i want safe mode or normal and after i choose eithr it tries to load up but never goes beyond the same point for awhile and fially the screen goes out to dark. what can i do?
  • 1 more comment
  • dyacob2 Jan 12, 2009
    Thanks for the help.
    I tried the diagnosis - fn + power. The screen remained black but beeps. The screen with battery alone works but as soon as I start using the power cord the screen goes dark.
  • dyacob2 Jan 20, 2009
    Thanks Rakesh and all for helping me out.
    I run diagnostics and showed me all pass
    but one.
    Here is what I saw ...
    " Test result Fail
    Error code 2000-0333
    Graphic test timed out waiting for keyboard response. "
    What's next for me now?
    Is this hardware problem or what?
    Also now the screen is not lighted even with the battery .
    All I see is everything on the background.
    I have to use my PC's LCD monitor to see what is out there.
    Pls. help this thing is killing me!
    thanks all
    yacob
  • KOPECKER Mar 16, 2009
    ERROR CODE 2000-0333 MY 1501 WONT STAY ON GOES TO WELCOME SCREEN FOR WINDOWS XP THEN GOES BACK TO F2/F12 SCREEN F2 NEEDING PASS WORD A FREINF OF MINE SAID THAT SOME ONE LOADED A BOOT LEG XP DISC AND THEN TRYED TO UPDATE WITH MICRO SOFT AND THEY LOCKED UP THE COMPUTER WHEN THEY FOUND OUT IT WAS A UP DATE
Hi Yacob
First Run a diags on the dell laptop. You can initiate it by pressing fn+power button together and start the laptop. It will go to the diags screen. Tell me if the diags pass or not and then we will troubleshoot further.
Thank you
Rakesh
Dell Laptop Expert
Posted on Jan 06, 2009
  • Anonymous Jan 14, 2009
    Could you check the place where u plug the ac adapter in the laptop is not loose?? it seems the like motherboard port is loose as system works fine with the battery.remove the battery and connect with charger and try to run the diags and let me know.
  • Anonymous Jan 20, 2009
    It seems like the lcd cable is loose or the lcd has gone bad.
    http://support.dell.com/support/edocs/sy... use this manual to check the flex cable which is black in color found under the hinge cover which connects between the lcd and the base of the laptop. if still it does not work u might have to replace the lcd.
Error code 3600:0749 dell inspiron 1501 . Result is the same if it runs on battery or AC alone (no battery in laptop).
Check the system battery information and charger information of the computer restart the computer, while the computer is booting up, press F2 repeatedly check "battery info"
If it stated ac adapter = unknown device update the BIOS
Click on drivers and downloads
Click or choose by service tag
Download the BIOS and install it on the computer
Check information after updating if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery.
Here is your products support site: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&os=WW1&osl=en&SystemID=INS_PNT_1501&catid=-1&impid=-1 Try to update all the drivers there is outdated. Hope this will help you.
Mar 13, 2011 | Dell Inspiron 1501 Notebook
Have dell inspirion 1501 no lites come on with power cord or with battery. nothing happens.
First try a different AC adapter, see if the system will power on.
If no change, then the failure is most likely the motherboard
Sep 25, 2010 | Dell Inspiron 1501 Notebook
I have a cracked screet with my my dell inspirion 1501 when i try to set it up with a dell flat screen monitor it flickers but does not recognize it and does not work.
go to your computer control panel & chec your resolutions pixels, or your hardware and sound to ajust your mobility setting.
Jun 29, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Black Screen
When you power up and everything finishes loading right click on screen and the personalize screen will appear .click on screen saver and to the left of the screen you will see a list that says change when computer sleeps you can reset the time there .Good luck
Jan 04, 2010 | Dell InspironTM 1501 Notebook
Dell Inspiron 1501 Notebook Logo
376 people viewed this question
Alun Cox
