Question about Dryers
Tumbler makes loud sound rattle sounds like something loose
We called an appliance repairman who replaced the worn out rollers. Expensive but quiet!
Posted on Jan 09, 2009
Loud rattle sound when Idling
I suggest you have your car checked as soon as possible - while a rattling exhaust isn't desperately urgent it could be the cat breaking up which might later restrict the flow of gases. Most importantly excessively loose timing belts or chains tend to make most noise when the engine is idling. If the noise is being caused by this delay could be very expensive.
Feb 24, 2016 | 2004 Lincoln Town Car
Waht would cause a loud rattleing noise in my engine?
get it into a garage before something really goes bad then you'll be looking for a new beamer
Apr 29, 2014 | BMW 325 Cars & Trucks
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Loud rattle coming from the bottom of engine. mostly heard after letting off the gas, starting and shutting off the vehicle.
Very hard to know without actually hearing the vehicle but,,,With what you describe,the cat/converter 'may' be making the sound.With the car off and engine cool,get under and give the cat/con a really give shove or hit.The insides of them do corrode and the internals make a very loud rattle.If this isn't the problem it will let you see if there is a loose exhaust mount that may also make a rattle.(The cat/con sound is like there is a very loose metal plate hitting something)Its actually the internals of the cat. that have broken loose and rattling inside it.Hope this helps
Apr 09, 2010 | 1996 Jeep Cherokee Country
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud Clicking rattle during spin
you may have something stuck in the pump
pull hoses off pump and see if there is anything stuck in it
Jun 13, 2009 | Admiral AW22 Top Load Washer
Washing machine makes a loud rattling sound
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Loud ticking/knocking/rattling sound when I start/accelerate
hi is it miss-firing as it sounds like a knocking noise can be anything but if you can feel it on the accelerater pedal then the noise sounds like its on the inlet valve side which would transfere the noise up the throttle body where the accelerater is located it could be something as simple as a tappet come loose to a burned valve you need to have a look do a compression test and take the rocker cover off see if theres anything come loose yates210456
Oct 13, 2008 | 2000 Dodge Grand Caravan
Loud dryer
sounds like somethings stuck inside the drum, between outer wall of drum and cabinet...please inspect for loose items..
May 10, 2008 | Dryers
Dryers Logo
77 people viewed this question
Top Dryers Experts
