Vizio TV Freezes
TV runs fine for 5-10 minutes then picture freezes but sound continues. The remote stops working as well.  When I turn the TV off and then back on the TV works again for another 5-10 minutes before freezing again.  I am using a DTV antenna.
  • 2 more comments
  • vinceskahan Feb 28, 2009
    a dozen tv crashes since I got it in early December on my 37" tv. Symptoms are the screen freezes with no sound. Only fix is to unplug the power cord.
  • Anonymous Mar 26, 2009
    same
  • Anonymous Apr 03, 2009
    Same thing. Does it happen to you often?
  • Anonymous Apr 07, 2009
    Same problem - it has done it 4 times and is a brand new monitor
    I'm going to exchange it for another
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
  • 19 Answers
SOURCE: LG LCD flat screen TV - 42LG50-remote control is unresponsive
Sounds like a probable main board issue
Posted on Feb 21, 2009
Shuttle83
  • 1139 Answers
SOURCE: SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
SOURCE: Vizio L32 DTV menu freezes
Hi did anyone replied to you? i am having the same problem. if you know any fix... PLEASE... Please .... let me know
Posted on Dec 23, 2009
ellao
  • 10 Answers
SOURCE: My picture freezes on the Tv and i have unplug it
The main board for this unit seems to be defective. The part number for this model is: 3320-0032-0150. Encompass has it new for $180.00+shipping. It will be a good idea to veryfy that this is the right part number, cause I have seen vizios with the same model number to have diferent main boards. Good luck.
Posted on Mar 10, 2010
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Mar 30, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Open Questions:
Televison & Video Logo
371 people viewed this question
Top Televison & Video Experts
