Question about Bosch 24 in. SHU43 Built-in Dishwasher
Water fills bottom of washer but doesn't get sprayed around
I haven't used the dw for about 6 months. now when i start it, the water gets pumped in, i hear all the "normal running noises" but when i open the door (sever seconds later) there is no water in it. no water is being sprayed from the top or bottom sprayers. when i hit cancel/drain the water gets drained out.
  • Anonymous Mar 26, 2014
    The pump seems to be running fine and it looks like the normal amount of water in the washer, but dishes aren't getting clean and if you open the door while it is running, you can see that there is barely any water coming out of the spray arms.
  • 67 Answers
This is the problem with these units, you have to pull it out to get to anything.when they work they are nice but when they break they are a pain in the a---- you get my idea
Posted on Jan 07, 2009
  • 318 Answers
You must have been eating out for a long time now. 6 months with no use will cause the wash pump to seize up and not spray water. if you can get to the motor and try to turn it by hand and that may get the shaft freed up and allow it to turn again.
the biggest problem is to get to the motor you will have to remove the unit from your cabinet and then you can reach the motor.
once you can get to the motor turn the shaft and then hook it back up.
this is the problem with these units, you have to pull it out to get to anything.
when they work they are nice but when they break they are a pain in the a---- you get my idea!!
Posted on Jan 06, 2009
The machine does not fill with water, pump start to work as soon as you switch machine on.
The item number 4 is for your problem. I think that the Float is stuck.
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 11, 2014 | Dishwashers
Smeg di612ca dishwasher won't drain water
Good luck. Did you have to dishes without a dishwasher once? If this doesn't work think of it as a pleasant reminder of the good ole days, whilst scrubbing them by hand at the sink. Use an apron to keep from getting wet.
Dec 21, 2013 | Dishwashers
Whirlpool dishwasher quite partner 2 push start button the cancel drain comes on wont start cycle
Number 4 is for you. This may be the problem.
Otherwise start here: Is their debris in air gap or in the bottom of the DW, where the drain is screened?
Good luck.
Nov 04, 2013 | Dishwashers
How do I clean the drain filter assembly on may tag dishwasher mdb4651awb
Sometimes this can only be gotten to by unscrewing the bottom spray arm in the basin of the DW. First, look in the bottom of your DW to see if you can unclog the screen by hand. This is the Drain Filter Assembly. It screens the waste so the pump doesn't get clogged. If you swipe stuff on the bottom of the DW like that leaf lettuce and rice, this might help.
Good luck.
Nov 03, 2013 | Dishwashers
Hi I have had this intake/drain light come on in my Miele G851 SC dishwasher. I followed the recommended instructions in the manual: - clean triple filter, drain pump, and non return valve - check...
Is their debris in air gap or in the bottom of the DW, where the drain is screened? Look for obstructions.
Good luck.
Oct 25, 2013 | Miele Dishwashers
Water not draining and backwash part missing
For the first problem, Is their debris in air gap or in the bottom of the DW, where the drain is screened?
Good luck.
Oct 24, 2013 | Bosch Dishwashers
Makes a squeel while filling, only while filling on the right side
The squealing is coming from the impeller seal on the water pump. You can try to lubricate the rubber impeller seal with silicone spray lubricant. If that doesn't work, replace the pump.
It the squealing goes on too long (weeks/months), the seal will begin leaking water onto the pump. Eventually, the pump will rust and short out, possibly ruining the electronic control board -- which can cost big $$.
Feb 12, 2011 | Fisher and Paykel GWL11 Top Load Washer
Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Oct 04, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
116 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
