Question about ViewSonic VX900 19" Flat Panel LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
My 3 yr old lcd vx900 monitor suddenly went blank except when I cycle power. The image then appears just fine for one second and then goes blank again. View sonic said it was the inverter (power). And would cost $120. Does this sound right?
  • 1 more comment
  • tallest Feb 23, 2008
    exactly the same problem that I have. The screen only flashes on for a split sec and then goes black.
  • patrick417 Jun 21, 2008
    Yes I have the same model with the exact same problem.
  • TenForty Nov 05, 2008
    Same problem. When I turn the monitor on, the image flashes for a fraction of a second then the screen goes black (but the green light stays on which indicates the computer is still sending it the signal). Same whether I use DB15 or DVI.
    Sag179@Yahoo.Com
No, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
Posted on Jul 13, 2007
Search for "VX900 inverter" on eBay. A company from China sells for $21, new, free shipping.
Posted on Nov 05, 2008
  • TenForty Nov 16, 2008
    Yes. The inverter WAS the problem. LCDPart.Com sells it for $80 and has a PDF document that guides you to change it. If you are on a budget, an outfit from China sells them on eBay for $21, shipping, included. The only problem is that their part is wider and shorter. So, although it works, you have to tape it down in place because it does not fit where the original comes.
My screen suddenly went black. What can I do?
Check to see if you do have 12vdc output from the power supply module, then also check the fuses on the backlight inverter board.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/?start=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 24, 2010 | ViewSonic VX900 19" LCD Monitor
When booting up my system in the morning the monitor is blank for about 15 minutes then it pops on. During the 15 minute warm-up there is a very dim pulsating of the screen every 3 or 4 seconds.
One bad lead can cause a computer lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
The power light is red and blinking rapidly, screen blank
is it plugged into wall or a surge? may make a difference. Some screens require certain amount of KV and some surge protectors have less KV than needed to run some things. good luck
Oct 01, 2009 | ViewSonic VX900 19" LCD Monitor
LCD Panel went dark al of a sudden
It could be a faulty inverter or a faulty CCFL lamp.
Check LCD Parts for parts, service and DIY info etc. Use this link.
www.lcdparts.net
Jul 25, 2009 | ViewSonic Computers & Internet
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Vx900 dispays for a second and goes blank.
is the vx922 worth fixing? my neighbour found it now i trying to fix it. wheres the capacitor, or the other thing to look at, as the screen goes black but button stays green..... i need diagram or simple play by play.
Apr 17, 2008 | ViewSonic VX900 19" LCD Monitor
Blank screen +
ok " if it was me i would not waste money on an old monitor, something else could go on it,
get a new one. or a newer used one
Jan 20, 2008 | ViewSonic VX900 19" Flat Panel LCD Monitor
Viewsonic VX900 blank screen
Here is a pic of the fuses on the inverter board for a Viewsonic vx900, you can visually inspect them as well if you do not have a volt meter. While visual inspection is not 100% reliable, usually when these are popped you will see the red line across them is black or broken.
Dec 06, 2007 | ViewSonic VX900 19" LCD Monitor
Computers & Internet Logo
1,036 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
