Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's
http://www.megxon.com/techsupp/download/X3/X3_supp.htm
Driver install
1. Download driver file "X3_Driver.exe" and save it to PC hard disk.
2. This driver file is a self-extracting archive, run it and it will extract automatic.
3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting.
4. After, in hard disk will create a "X3 Driver" folder.
5. Enter "X3 Driver" folder and find "Install" folder.
6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation.
How to set the USB function to PC Camera or Storage mode
(Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.)
When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode.
1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section.
2. Then press right key to "Setup".
3. Press down key to "USB" then press right key.
4. Press up or down key and change it to "PC camera" or "Storage".
5. Press "OK" key to confirm.
How to Format internal memory or memory card
(Regarding how to format, please reference user manual page 27. )
> Formatting SD Card
Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps:
1. In "Capture" mode, press "MENU" button into the setting mode.
2. You can see "Capture" and "Setup" in the screen.
3. Press right key to "Setup" then press down key to "Format".
4. Press right key to next step.
5. Press down key to "Confirm".
6. Press "OK" button to confirm. The SD card will be formatted.
> Formatting the Internal Memory
Take out SD card from the slot and format the Internal Memory by following the above mentioned steps .
NOTICE
1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function.
2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 |
Megxon X33 Digital Camera
