Question about Lexmark X83 All-In-One InkJet Printer
Lexmarkx3470- will print,won't scan
New computer, windows vista, install ok,maintenance check ok, says working properly?
    President:
  • 2,692 Answers
I have to ask. Did you install it via a disk that came with the printer? If so , did the disk specify that it was for the VISA version of windows?
Below is Lexmarks support website for your printer:  http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Jan 06, 2009
It's brand new. Bought it off ebay. Got it hooked up to computer windows vista. It will print but it won't copy or scan. All I really need is the copy but it won't. it prints fine
Did you run the installation CD that came with it? That installs all the drivers, which include scan, copy and print. Vista installs generic print drivers, which is probably why you can print. On some printers, the copy and scan commands run from the printer control panel, sometimes via the installed software.
Incidentally, Vista was one of the most hated versions of Windows, only slightly in front of Windows Millenium Edition! You should try Win7, 8, or 10. They are far superior.
What is the make and model? Reply by COMMENT so I get notification.
May 17, 2016 | Office Equipment & Supplies
Lexmark X1185 (print trio) does not scan or copy since upgrading to Vista
Hello Barbhinkins,
Please find the vista driver for this printer at this link. Follow the instructions to install properly.
Hopefully this file will also have driver for scanner.
Thanks,
Lolita
Aug 15, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
I can't find software for Brother MFC-6800 printer for Vista....I can print only..I can't find scan, copy software for vista
The OS has a built-in driver that should automatically install when the USB cable is connected. Check Windows Update for new and optional updates if you don't see the printer appear. If you use a bi-directional parallel cable (with the computer properly set up), use the Printer Wizard and then the Add Device Wizard (IIRC). The scanner won't work over the network.
Try using one of the programs built into Windows: Windows Fax and Scan (New Scan), Paint (File > Import from Camera or Scanner > New Scan) or Photo Gallery to launch a scan. Alternatively, get a third-party software option (Paperport, for example).
Go here: http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/dlf/download_top.html?reg=us&c=us_ot&lang=en&prod=mfc6800_us to get a utility to improve the scan resolution.
I hope this helps.
(Scanner problems can often be resolved with a new data cable and a direct connection between the unit and the computer. This assumes that the scanner is unlocked (for those with a transport lock) and that the unit is properly lighting up and the scanner is moving freely.)
Nov 22, 2010 | Brother MFC 6800 All-In-One Laser Printer
Canon mp600 scan problem vista windows 7, does not scan print ok,
Do you have Windows Vista or Windows 7? They are two different OS. Drivers are available here. If you haven't downloaded and installed the latest drivers, uninstall all drivers on your computer before installing these. Be sure and download/install the MP Navigator also.
Nov 11, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Hp color jet 2840 cannot scan on windows vista but can print
The problem is Vista. I had a similar problem and the only solution at the time was to remove vista and install good old reliable XP. Now just put windows 7 on and you should be ok.
Aug 14, 2009 | HP LaserJet 2840 Printer
My lexmark x2400 all in one printer
You have probably installed the XP driver from your CD. You need to remove it, and then install the proper "Vista" package from Lexmark's website. Here: http://www.lexmark.com/lexmark/sequentialem/home/0,,204816596_652569478_0_en,00+en-USS_01DBC.html
Jun 07, 2009 | Acer Office Equipment & Supplies
Printer will not install on vista operated computer
pardon me for asking if you have downloaded the driver for Vista? pls ensure that you have done this otherwise it will not really print becuse of incompatible drivers.
or pls check if there is already a presence of a printer in your computer, then right click the proprties and hit test page.
Dec 04, 2008 | Office Equipment & Supplies
Hp psc 1215 wont scan with vista
Introduction Some products do not have full scan functionality in Windows Vista. This is because full-featured Vista drivers are not available for all products, especially older products. However, the Windows Vista operating system installed on your computer includes a basic print driver. This driver allows you to scan an original and save it as an image using workaround methods. You cannot use the advanced scanning features that you might have used with your product before you installed Microsoft Windows Vista. Scanning an original and saving it as an image Follow these steps to scan an original document, and then save it as an image. Step one: Load the original Follow these instructions to load the original in the product.
  1. Raise the top cover of the product.
  2. Place your original print-side down on the glass.
    NOTE: The engraved diagram next to the scanner glass shows exactly where to place the document (usually on the right-front corner or the left-front corner).
  3. Close the scanner lid.
Step two: Workarounds for scanning an original and saving it to the computer Select one of the following three workaround methods to scan an original and save it as an image. Method one: Scan with Windows Photo Gallery
  1. Click the Windows (c01319360.gif ) icon.
  2. Click Programs .
  3. Click Windows Photo Gallery . The program opens in a new window.
  4. Click File , and then click Import from Camera or Scanner .
  5. Click Import .
  6. Click Scan .
Method two: Scan with Windows Fax and Scanning
NOTE: This feature and the following instructions work only with Vista Ultimate, Vista Business, and Vista Enterprise versions of Windows.
  2. Click Programs .
  3. Click Windows Fax and Scan . The program opens in a new window.
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scan using Paint
  2. Click Programs .
  3. Click Accessories .
  4. Click Paint . The program opens in a new window.
  5. On the Paint toolbar, click File , and then click From Scanner or Camera .
  6. Click Scan .
Nov 30, 2008 | HP PSC 1215 All-In-One InkJet Printer
Hp psc 1350 all-in-one
Source: HP support
( Click link above to read complete article and instructions )
Introduction A full feature software and driver package for Windows Vista is not available for your product. However, the Windows Vista operating system installed on your computer contains a basic driver solution for your product. With the basic driver, the buttons on the product do not function and some of the advanced product features are not available. But you can still print, scan, and import and view images on a memory card, using the workaround procedures in this document. Use the following instructions to install the basic driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the printer driver When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Workaround procedures The basic driver in Windows Vista is sufficient for several functions. You can print from a software program, scan documents, and import and view images on a memory card. Printing Use these steps to print from a software program.
  1. Open the document to be printed in the software application in which it was created.
  2. Click File , and then click Print .
Scanning Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367391.gif ) icon.
Oct 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
