Question about Whirlpool Calypso GVW9959K Top Load Washer
Water Leaking From Calypso, Won't Drain Completely
I have a similar problem. My Calypso won't go through a whole cycle. After cleaning up much water from a fast leak and completely emptying the water from the washer the machine seems to be leaking from somewhere on the back side near the top and spilling down. There is some type of long,tube-shaped clear plastic (almost like a a ziplock bag material) that is hanging from the possible source of the leak and when I try to cycle the machine through a rinse and spin cycle suds are emmited through and around the plastic tube. I want to take the hoses off to try to try to see if there is some type of clog but I am worried that more water will spill out as the machine appears to have much water down in the holding tank below(there is also more water in washer since I have attempted more partial cycles.) I believe this water needs to be emptied before I can run a successful cycle on the machine but there seems to be no way to get it out. PLEASE HELP!!!!
  • 2 more comments
  • Anonymous Jan 06, 2009
    Thank you for your response, however all we have ever used if HE Detergent. This particular type of detergent that was used when the machine broke was TIDE HE Frontloading not Toploading. Could this difference in HE detergents be the reason why we are having this problem?
  • BDS1111 Jan 06, 2009
  • BDS1111 Jan 07, 2009
    Thanks again for the info. I emptied the water from the washer agian after messing with it for a while, took the back cover off and unplugged electricity/water hoses/drain hose from the washer and then proceeded to unhook the drain hose from its mounted postion up along the back of the washer. I discovered that this allowed the drain hose to be lower than the holding tank and allowed most all of the holding tank water to drain out into a pitcher I had to catch it. I guess that this means there is probably not a blockage? I am trying to decide whether to hook everything back up and try a dry run without detergent or to dismantle the hoses as you suggested and check for further blockages. What should I use to take the clamps off the hoses, as they appear to be very tight?
    I think the problem is fixed. I turned the washer on its front and took the bottom off. I used channel locks and took the hoses from their joints. The U-shaped piece that attaches to a spinning machanism as well as two different hoses was where the problem was located. There was a lot of big bathroom carpet debris from the load that was in when the washer stopped that had prevented the spinning wheel inside the u-piece to completely jam up. This appears to be the only blockage. I put everything back together and am running an empty test load right now. Thanks a lot for your help! I will be back if more problems persist though.
  • 318 Answers
The bag type device is an overflow and should never have "water"in it, but it will get suds if you are using the wrong type of soap.
you need to use "HE" soap as it is a non-sudsing soap and thats why you are getting suds leaking from your unit.
just run the rinse and spin cycle until the suds are gone. then use the right type of soap and it will work properly with no leaks.
Posted on Jan 06, 2009
  • 1 more comment
  • Tom Zwiebel
    Tom Zwiebel Jan 07, 2009
    any type of HE soap will work in your washer, there is no difference in a front loader or a top loader if they are they high efficiency units such as yours is.
    it sounds like maybe you are having a drain problem as well, but be sure that you are not using too much soap as well.
    then there are 2 things to
    check next. make sure the lid does close and lock so the machine can
    run, and if it does try to run, but wont drain, then you need to check
    the drain pump to see if it is blocked with something like a quarter or
    a sock.
    you can get to the pump from the rear panel and then be
    ready to catch the water so you can remove the hose going into the
    pump. do check both pumps, 1 is for recirculation and the other is for
    draining.
  • Tom Zwiebel
    i usually use a channel lock type pliers or any type of a slip jointed pliers will do.
    i would take the hose off and see if you have a quarter or a coin in the hose.
    by taking the hose down you have proven there is no sock blocking the hose but a coin can act like a valve and turn sideways one time and then flat the next causing no drain. since you already have the water out and the back off, now would be a good time to check inside the hoses at the pump.
  • Tom Zwiebel
    nice job. glad i could be of some help.
My kenmore elite calypso washer won't fill up enough to get clothes completely wet.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 17, 2013 | Kenmore Washing Machines
Calypso washer won't drain
It sounds like you may have something stuck in the pump...try and locate the pump(normaly at the bottom of machine)and unscrew the cover...be aware that the machine may still have water in it....once you unscrew the cover,have a look and a feel inside...there may be a coin or other object stoppint the pump from turning...remove any foreighn object...replace the screw on cover and try to drain the water again....this should solve your problem.
Jan 17, 2013 | Whirlpool Calypso GVW9959K Top Load Washer
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
My whirlpool calypso won't drain after I removed the rug particles wrapped around the drain pump fan. Showing LD code
You will need to replace the pump. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 14, 2012 | Washing Machines
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Bosch Vision 500 washer won't fill with water. i! Yesterday we got a E13 error with the washer. The door wouldn't unlock, so I removed the front panel to unlock it manually. I also cleaned out...
Hi
You are right, E13 is a long drain time error and to solve this issue the pump filter assembly should be cleaned completely. There is a tiny hole you can stick a pin through in the access panel on the lower front right corner. Push a pin through the whole and turn the access panel counter clockwise and it will remove so that you can unscrew the plastic drain cap behind it. Remove the plastic drain cap and clear the drain behind it. After doing all these things if the issue returns then it means the drain pump is faulty and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 12, 2011 | Washing Machines
Calypso washer won't spin and drain properly
i've pulled stuf from many a calypso pump and its not the funest pump to clean.some designs never get stuff in the pump others its like theres a sock magnet in there or somthing.your has got a sock magnet.take off the frount and you will see the pump on the right.white,it has two hoses.take the inlet off first if eazyest then will only have to take one hose.you can geter done.God bless,tom
Jan 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
351 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
