Question about Kenmore Refrigerators
Leaking water in bottom of freezer
It is a side by side unit about every two to three days there is a 3/8 to 1/2 recess the length and width of the bottom of the freezer that fills with water and freezes then the next time it fills with water it goes across the ice and leaks out of the freezer door and puddles on the floor
    President:
  • Kenmore Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Jan 06, 2009
What is the perimeter of a 1 x 3 rectangle?
Rectangle has two pairs of equal sides.
L=length=3 units
w=width =1 unit
Perimeter = sum of the measures of all sides.
2 sides with measure L: sum of lengths=2*L
2 sides with measure w: sum of widths=2*w
Perimeter = 2L+2w=2(L+w)=2(1+3)=8 units.
Oct 29, 2013 | Mathsoft StudyWorks! Mathematics Deluxe...
Perimeter of a 1 x 3 rectangle
L=length=3 units
w=width =1 unit
Oct 29, 2013 | Computers & Internet
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Water leaking from freezer compartment
try finding out where the condensate from the auto defrost is going,is there a drip tray (rear bottom)thats full and (naughty)have you been loading freezer with warm food.....
May 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water in freezer bottom and water leaking out from
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Water leaks from bottom of freezer side even though the water is turned off. Also makes a humming noise prior to leak. Leaks about every 3 days.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
Apr 22, 2010 | Maytag MZD2766GES Side by Side...
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Water leak from my Kenmore refrigerator
Your problem is most likely a clogged drain line. Which is located in the back bottom of the freezer a little hole. Run some hot water down it with a spray bottom and it should resolve your issue. Also yes a Tech will be able to fix this problem
Jun 01, 2009 | Refrigerators
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Leak running down front
Take the recess cup out and seal the area around it right where the front stainless steel panel meets the recess (right at the front of the recess) with clear silicone to prevent water from getting inside the door, then running out of the plastic frame area around the dispenser and running down the freezer door or out the bottom of the door. After the silicone has set, replace drip cup.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
201 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
