Question about HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop
Computer won't turn on
My computer won't turn on and the power button is flashing orange. Help please!!!
  • julian_nicol Jan 06, 2009
    It's not my monitor and i checked my ram. I even reset it.
  • 139 Answers
Very simple remove your system power cable the display cable from the CPU now press the power key for 1 min. Plug the power cord back and attach the display cable.
( Note - Remove power cable and display cable then press power key for 30 sec )
Your system will work.....
Enjoy..........
Posted on Jan 08, 2009
    Sergeant:
    Champion:
  • 277 Answers
Check your monitor connection and memory ram
Posted on Jan 06, 2009
Sharp Mebius won't boot
I suggest that you remove the battery and use the charger only in turning on your computer. If it turns on just fine without the battery then you would need to replace the battery. If it doesn't then it's either the motherboard or the charger which has a problem.
David
Jun 10, 2013 | Sharp Mebius Computers & Internet
Orange light flashing, no chargine
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Jan 31, 2013 | Dell Latitude E5500 Laptop
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Won't Start Up
try this link it might help you get start again. laptop Won Start Up Google Search
Oct 19, 2017 | Toshiba Tecra TE-2100 Notebook
Many issues, ie, Everything is flashing!
Hi there
yOU CAN ONLY TRY.
not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
237 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
