Question about Bose 023795 LCD Touchscreen Remote Control
Bose p1 touchscreen remote
Hi ross here having problems with my lifstyle 50 system remote cant make contact with interface willl not beep twice to confirm contact have brought a new remote but no luck. any help appreciated
  • fauxjoe Dec 16, 2007
    tried holding mute until beep, but no beeps after 10 seconds. Everything is connected and has power. Unit was working without trouble.
  • moriley Aug 18, 2008
    Same problem. Nothing happens after the first beep, that is, I never get the second set of 2 beeps.
Press and hold the mute key for about 5 seconds until you hear a beep, then wait about ten seconds
Posted on Aug 14, 2007
Lost remote for a olin ross sound system bougt a rca universal remote need code for the olin
  • Codes don't seem to be online. General consensus is that they are sold out of white vans and are scam bait. I did find remotes advertised though.
  • OLIN ROSS Replacement Remote Control for OR860, DV606 www.amazon.com > ... > Remote Controls > TV Remote Controls ... OLIN ROSS Replacement Remote Control ... Systems Speakers Wireless Audio Stereo System Components ... compatible with the following models of OLIN ROSS ...
  • Lost remote for a olin ross sound system bougt a rca ... www.fixya.com > Forum > Remote Controls > RCA Lost remote for a olin ross sound system bougt a rca universal remote need code for ... Lost remote for a olin ross sound system bougt a rca universal remote need ...
  • OLIN ROSS Replacement Remote Control for OR860, DV606 ... www.newegg.com/Product/Product.aspx?Item=9SIA3711082020 OLIN ROSS Replacement Remote Control for ... remote made by Redi Remote for the OLIN ROSS part number DV606 This remote control is compatible with the following ...
  • OLIN ROSS OR880 5 1 Surround Sound System Subwoofer 5 ... www.ebay.ca/sch/sis.html?_nkw=OLIN+ROSS+OR880+5+1+Surround+Sound... OLIN ROSS OR880 5 1 Surround Sound System Subwoofer 5 Speakers Bose retail 350 0 results. You may also like
  • RC: Olin Ross remote issue www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?9216 Olin Ross remote issue. Login: Pass: Register . ... I have an Olin Ross or860 got it from a secondhand ... mean it is a actual Olin Ross system, but thats what I ...
  • Oct 02, 2016 | RCA Televison & Video
    2000 stratus beeps twice, flashes twice, repeats untill stopped, but it drives
    This is usually a good situation to bring to alarm shop and have them take it out and see if you can just keep the remote start or it might need a new brain on the alarm system
    Dec 10, 2013 | 2002 Dodge Ram 3500 Truck
    Lifestyle 50 not responding
    Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
    Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
    Need operating manual for viper ce 0890
    The asterisk button controls the remote starter feature. Press and release one time, wait. The parking lights should flash confirming that the unit received the command. If pressing the button one time doesn't work, try two times.
    Jan 24, 2013 | Remote Start System
    BOSE LIFESTYLE 50 REMOTE CONTROL NOT WORKING
    FOR THE BOSE LIFESTYLE 50 SYSTEM (Model P1 - Personal Music Center remote)
    You can re-calibrate the remote first by following the steps below:
    1. press and hold down on the display screen in the top middle area of the remote
    2. After a few seconds the word CAL will appear in the middle and the word SOURCE will appear in the top left area of the remote.
    3. Press the SOURCE button.
    4. The word KEYPAD will appear in the top right area of the remote
    5. Press the KEYPAD button and a small circle will appear in the bottom right of the remote.
    6. Press the Circle
    This should've recalibrated the remote.
    If you need to relink the remote to the system, HOLD down the mute button while having the remote as close as possible to the unit. You will hear a beep . Release the button, after a pause , you will hear the remote beep twice.
    This re-links the remote to your system
    If the backlight is not working, your options are
    1. Spend $349 and get a new one from Bose Or
    2.Spend $220 and get a used one on E-bayOR
    3. Use your remote with the lights on so that you can see the display :-)...the cheapest way OR Invest in an LED Book light that you can clamp on the remote and use that for your light ($9.99)
    Sep 10, 2012 | Bose LifeStyle 50 System
    I have a Digital Lifstyles 42
    If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
    Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
    GOOD LUCK....
    May 21, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
    Hi i have just reinstalled xp home.cant conect to the internet its telling me i have no network adaptor or ethernet controller.worked fine before i reinstalled .i brought my comp second hand ftom acomp...
    Pleasse reinstall your NIC driver (Network Interface Card). Check your device manager for make and model of your NIC. Download the proper driver to some other computer and put it on a disk which will work in your unknown computer (floppy if available, CD if no floppy)
    Thanks for your interest in FixYa.com. I hope this helps you
    Please vote
    thanks
    a
    Nov 15, 2009 | Computers & Internet
    Lifestyle 50 "No Response"
    The remote problem is same with me and need to repair.
    I gots information from Bose Service Center, PCB transmitter and receiver not working well.
    maybe this information helpful for you.
    tq.
    Aug 18, 2008 | Bose 023795 LCD Touchscreen Remote Control
    Hyundai MHD 201 p
    sir/mam
    ross
    it is not a problem of monitors is you sound system
    Mar 24, 2008 | Computers & Internet
    Bose 023795 LCD Touchscreen Remote Control Logo
    3,122 people viewed this question
    Top Bose Televison & Video Experts
    George Scott
    George Scott
    Jerry Greenberg
    Jerry Greenberg
    Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
