Question about Dell 3100MP Multimedia Projector
3100MP DELL Shuts off after minutes of use
My Dell projector 3100mp shuts off after minutes of use. When I turn it back on, it shuts off even quicker than the first time. The symptoms seem to indicate thermal shut off issue. The bulb works ever time, it's just the unit that turns off. Is there a simple fix of changing a board? Or is the bulb near the end of its life and is it overheating causing the unit to shut down? The shutting off started doing this after I connected my new blu-ray system and started using the composite 1080i connections (also, there is green around my boarders that i don't know why ... maybe you can tell me what that is too? It may be due to the keystone adjustments as it is only in the keystone slivers on the sides). Someone said I may be overheating it since the blu-ray is a 1080p and it is not compatible with the 1080i on the Dell unit (not sure I believe this).
  • 236 Answers
SOURCE: Unit shuts itself down
Sounds like you have an overheating problem. Maybe a bad fan? Also you may have a bad connection to the "bulb".
Stargazer
Posted on Mar 16, 2008
SOURCE: Dell 2200MP projector
We have had two and they both did the same thing. We sent the first one back because it was still under warrenty, they sent us another one, it does the same thing.
Posted on Aug 15, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Posted on Dec 17, 2008
I think I had a similar problem- are you connecting to the right socket.? The VGA on the 3100MP socket is `VGA out` you might need to connect to the `DVI monitor in` socket ,possibly needing a male DVI connector that connects to a male VGA lead.(Maplins , if you are in UK ,sell one for about £10)
Posted on Jan 05, 2009
myrlex
  • 674 Answers
SOURCE: Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Posted on Jun 19, 2009
Power supply fuse
HI,
Do you need to know the rating of fuse used in the power supply. Or do you mean that Power supply is not working.
Jan 04, 2013 | Dell 3100MP Multimedia Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Hi, is Dell 3100MP Projector is compatible with windows 7 laptop. I am Having message " NO SIGNAL, CHECK VIDEO CABLE" with Windows 7 but with Windows xp, the same projector works fine. Can anyone...
In most cases this problem is cured by enabling the external VGA (or monitor) ouput on the laptop. The quickest way is to reboot the laptop with the projector turned on and connected. Usually the laptop will detect an external display is attached and enable the port.
It is also possible to manually enable the external display port. It varies from laptop to laptop but look for the "Fn" key at the bottom left of the keyboard, usually coloured green or blue. You should see a row of icons on the top row of "F" keys which is in the same colour. Look for the one which is either a monitor, or possibly says LCD or CRT.
Hold down the Fn key and press the key you located in the last step. There is usually a delay of a few seconds and then you'll find something may happen. Usually the external output will be turned on alongside the local (laptop) display. Repeatedly following the last step cycles through all available configuration options, including both on, local on, local off, external on, and external off.
This should fix it. Make sure that the correct input is selected on the projector whilst doing this. It will be labelled on the projector and it should display the same input message on screen.
Feb 21, 2011 | Dell 3100MP Multimedia Projector
Dell 4100mp shuts down
It sounds like the fan in you 4100 is defective.
Jul 14, 2009 | Dell 4100MP Multimedia Projector
Jun 19, 2009 | Dell 3100MP Multimedia Projector
No Sound
check the setting of sound.. if its okay check the speaker wire connector or the chips.. but be care full for opening if you can open and fix no problem..
or look qualified technician for projector
Feb 03, 2009 | Dell 3100MP Multimedia Projector
Smd board to board connector rework
try the hako solder rework station,dont ever try an ordinary solderinr.form what u have mentioned , it appears the connector is alrady short.suggest you to rmeove the connector with hako or similar solder rework station & if the connector isnot damaged during rework, resolder using the same station or buy a new connector.this hsould solve ur prob
Feb 02, 2009 | Dell 3100MP Multimedia Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Bad SMT connector on main board
mmm. a very small tipped soldering iron
while working under a mantis pcb magnifier.
you'll need a steady hand.....
don't however try to remove the sm connector, this will probably only wreck the pcb. try to use small wires to make the connections and bypass rather than try to rescue the connector.
Feb 25, 2008 | Dell 3100MP Multimedia Projector
Dell 3100MP Multimedia Projector Logo
233 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
