Question about Epson Stylus photo C87 InkJet Printer
Lamp blinking tools for software
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Replaced projector lamp and my lamp light still blinks
Hello, make sure that all the covers are on properly, was the old lamp broken? If it wasn't it may have not been the problem, sometimes the ballast board will cause the lamp light to blink like the lamp is bad....tks
Jan 21, 2015 | Mitsubishi WD-60735 Compatible TV Lamp
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Interior lights blink off and on, does not stop
Interior lights blink off and on ????? As in dome lamps, dash light's etc...??? An what the heck is this mean We were told to hinge the module?????? I have been an automotive technician over 30 yr's an never heard the term hinge the module. The interior lighting on your vehicle is controlled by the smart junction box , ford's BCM body control module . ( Electronic's ) Who checked the vehicle ? Dealer ?
Interior Lighting The interior lighting system consists of the following:
  • Smart junction box (SJB)
  • Interior/map lamp assembly
  • Rail lamps (if equipped)
  • Glove compartment lamp assembly
  • Dimmer switch
  • Illuminated vanity mirrors (if equipped)
  • Rear cargo lamp
  • Puddle lamps (if equipped)
  • Door ajar switches
  • Liftgate glass ajar switch
The interior lighting system consists of 2 subsystems:
  • Courtesy lamps
  • Demand lamps
The courtesy lamps are controlled by the SJB. The courtesy lamp subsystem consists of the ajar switches, the interior dome lamps, the puddle lamps, the roof rail lamps, the cargo lamp, and the overhead console lamps (if equipped). The SJB supplies voltage to the courtesy lamps when the SJB receives the required input.
The demand lamps subsystem consists of the glove compartment lamp, the dimmer switch, the cargo lamp, all map/reading lamps, the roof rail lamps, and the LH and RH vanity mirror lamps.
The SJB supplies power to the interior lighting system. The SJB sets DTCs if certain circuit failures exist with the interior lighting system.
Visual Inspection Chart Mechanical Electrical
  • Courtesy lamps
  • Map lamps
  • Vanity lamps
  • Smart junction box (SJB) fuse(s):
    • 9 (15A)
    • 10 (15A)
    • 25 (10A)
  • Circuitry
  • Courtesy lamps
  • Map lamps
  • Cargo lamps
  • Vanity lamps
  • Dimmer switch
  • SJB
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. NOTE: Make sure to use the latest scan tool release software. If the cause is not visually evident, connect the scan tool to the data link connector (DLC).
  1. NOTE: The vehicle communication module (VCM) LED prove-out confirms power and ground from the DLC are provided to the VCM. If the scan tool does not communicate with the VCM:
    • Check the VCM connection to the vehicle.
    • Check the scan tool connection to the VCM.
    • Refer to Section 418-00 , No Power To The Scan Tool, to diagnose no communication with the scan tool.
  1. If the scan tool does not communicate with the vehicle:
    • Verify the ignition key is in the ON position.
    • Verify the scan tool operation with a known good vehicle.
    • Refer to Section 418-00 to diagnose no response from the powertrain control module (PCM).
  1. Carry out the network test.
    • If the scan tool responds with no communication for one or more modules, refer to Section 418-00 .
    • If the network test passes, retrieve and record the continuous memory DTCs.
  1. Clear the continuous DTCs and carry out the self-test diagnostics for the SJB.
  1. If the DTCs retrieved are related to the concern, go to the Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Chart or the Power Liftgate Module Diagnostic Trouble Code (DTC) Chart. For all other DTCs, refer to Section 419-10 .
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Chart DTC Description Action B1320 Driver Door Ajar Circuit Open Go To Pinpoint Test C . B1328 Passenger Door Ajar Circuit Open Go To Pinpoint Test C . B1331 Decklid Ajar Rear Door Circuit Failure Go To Pinpoint Test C . B1336 Door Ajar RR Circuit Open Go To Pinpoint Test C . B1572 Door Ajar LR Circuit Go To Pinpoint Test C . B1688 Lamp Dome Input Circuit Short to Ground Go To Pinpoint Test C . B2077 Liftgate Ajar Circuit Failure Go To Pinpoint Test C . B2A35 Interior Lighting Output Circuit Open If the courtesy lamps are inoperative, Go To Pinpoint Test A .
If the courtesy lamps stay on continuously, Go To Pinpoint Test C . B2A36 Interior Lighting Output Circuit Short to Ground Go To Pinpoint Test A . B2A39 Puddle Lamp Output Circuit Open Go To Pinpoint Test J . B2A3A Puddle Lamp Output Circuit Short to Ground If the puddle lamps are inoperative, Go To Pinpoint Test J .
If the puddle lamps are always on, Go To Pinpoint Test L . All other DTCs - REFER to Section 419-10 .
Oct 08, 2017 | Ford Expedition Cars & Trucks
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
Infocus sp5000 red led blinks once indicating lamp
be sure and reset the lamp hours. Flash the software if you can. These are also notorious for the ballast cable on the inside of the lamp housing backing out when a lamp is removed or replaced. If you have the cover off push the cables back into place and hold them there as you install the lamp. Also look directely at your lamp in the center and move it side to side and up and down. If there are any cracks or frosty looking spots or bubbles in the mirror of the lamp that are visible, then the lamp is probably shot. If all this fails, most likely it is the power supply, or the lamp door has gotten mishapen from heat and the actuator on the lamp door isn't making full contact with the safety swith.
Jan 29, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Lamp issue
very easy to do yourself doesnt reguire any special tools and takes about 3 minutes
May 05, 2009 | Televison & Video
Hard time turning tv on and once on, will turn off after a period of time
Sounds like it may have been jarred or theres a larger tall capacitor in the power supply that goes bad in these sets alot. Its not something a layman should attemt. As a matter of fact the only thing in this set that is user replaceable, is the lamp. Sorry but your going to need the service manual and soecialized tools tom trouble shoot this set. you really should seek out a pro for this repair.
Sep 12, 2006 | Panasonic PT-40LC12 40 in. LCD Television
Epson Stylus photo C87 InkJet Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
