Question about Lexmark Optra M410 Laser Printer
Lexmark Opra M410 Laser
The printer pulls two sheets of paper from the paper tray resulting in blank sheets of paper between the printed output.
Are there any adjustments on the paper tray or the mechanism in the printer to prevent it from pulling multiple pages when it tries to print? Maybe a paper type setting somewhere I can't find?
Thanks!
  • Anonymous Mar 28, 2014
    paper comes out real fast one sheet after another
    Novelist:
  • 125 Answers
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
Posted on Jan 07, 2009
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
LexMark 5400 Series All-In-One Printer
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
Feb 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Every 10 prints or so a single sheet of paper will come out printed but will crunch up as it is feeding to the output tray. Nothing seems to be blocking it because not every page does it.
If you are getting blank pages between print jobs or between page or each print job, separator sheet must be turn off. By default NONE is the factory settings for separator sheet. You may restore factory defaults. to do this click on menu>settings>general setting>factory defaults.
Mar 08, 2011 | Lexmark C540N PROD SPECS TBD Printer
My Brother HL-5740 Is jamming after every print jog. It's pulling two sheets through, the first sheet with the print job and the second sheet clear, Its like every job has two sheets. The second sheet...
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Oct 16, 2017 | Brother HL 5140 Laser Printer
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
I don't have a owners manuknow how to change the paper trays from
Go to Menu, then Paper Menu. Select Paper Source then select Manual Feeder. You should also select manual feeder from the driver.
I'd like to add the link to download the User's Guide for future reference. http://www.lexmark.com/publications/pdfs/optram410/enUser.pdf. Hope this helps. Leave a comment if you need more assistance. Thanks.
Jun 29, 2010 | Lexmark Optra M412 Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
E240 LEXMARK WON'T PULL PAPER FROM TRAY 2
Try pulling out the tray and looking for the feed rollers that pull the paper up into the printer. The 2 rollers should have rubber "shoes" on them (they look like thick black rubber bands). Remove these roller "shoes", turn them inside-out, and put them back on the rollers. This worked for me, maybe it will work for you too.
Mar 31, 2009 | Lexmark E240n Laser Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Lexmark Optra M410 Laser Printer Logo
165 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
