Question about RCA HD50LPW42 50" Rear Projection HDTV
My RCA is screeching
My RCA HD44LPW62 makes a screeching sound when I turn it on. No picture or any other sound besides the screeching. It screeches for about 8 seconds then stops, the green light blinks 5 times then it screeches again. 2 days ago the color was all messed up then it seems to have fixed itself. Now I have nothing but screeching! I have purchased a new color wheel (part # 212184) for my RCA HD50LPW42 and am looking for instructions on how to install. Any help would be appreciated.
  • mista95 Jan 06, 2009
    I have the same issue except for I haven't bought the color wheel yet. Instruction would be great.
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Posted on Jan 31, 2009
2006 Chrysler sebring High Pitch Noise Screeching Sound
The belt is slipping or the compressor and/or clutch is bad.
If the compressor won't turn freely with the engine off, it may be locked up which will make the belt screech.
Jun 27, 2012 | 2006 Chrysler Sebring 2.7
No picture and loud screeching on RCA Scenium 50" DLP
It sounds like it is the Color Wheel. I do not think you can get the Color Wheel separate from the Optical Engine like you can with Samsung. RCA is very tight with there parts like that. Because you have to get the whole
Engine Assy, cost would be too much in my opinion to invest into it. The part cost approx 800.00 the last time I checked on one.
Good Luck,
I Hope this helped,
Skyassoc
Jun 20, 2009 | RCA Scenium HD65W20 65" Rear Projection...
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Wont turn on
there may be a short in the system. Bad news: You should have a licensed pro help you diagnose it and fix it. Good news: its fixable.
Aug 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD50LPW175
Sounds like the color wheel is failing.
Dec 18, 2007 | RCA HD50LPW175 50" HDTV
RCA HD50LPW42 50" Rear Projection HDTV Logo
495 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
