Question about Lexmark X5495 Printer
4 in 1 won't feed paper, makes a high pitched whine.
My 4 in 1 says it does not have paper when it does. Says to load paper and push select, but this does nothing. When it is asked to print, whether by incoming fax, making a copy or from the computer, it makes a high pitched whine. I have turned it off, re-booted the computer, cleaned everything I can reach, checked for paper stuck anywhere, etc but to no avail. It will even squeak when I turn the printer back on, but before I ask it to print again.
  • sophia_nixon Jan 12, 2009
    my printer will not print or copy, it acts like it will print but every time it starts the paper either gets jammed or will just not feed at all. Oh and the scanner just never seemed to have installed correctly on my computer. It always said "application error". I have reinstalled, and rebooted my software cleaned my ink cartridges and nothing tends to work.
  • Lexmark Master
  • 684 Answers
Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......Now try to Print it should work........
Thanku
Posted on Jan 21, 2009
Making a high-pitched whine when turned on
What is making a high pitched whine? Simple answer would be leave it off.
Jul 07, 2015 | Cars & Trucks
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
Printer makes a high pitched whirring sound, paper will not feed and orange light stays on
clear paper feed roller whit wet cloth or alcohol,
1. remove paper tray
2. look for paper feed roller just in bottom of printer.
3. clear it as i said early
4. Enjoy
Good luck!!!
Jan 17, 2011 | HP LaserJet 2200dn Printer
2000 Suburban: High-Pitched electronic whine near rear of surburb...
That "whine" is the fuel pump inside the tank. This usually gets louder at or below 1/4 tank. Expect the fuel pump to go out soon.
May 16, 2010 | 2000 Chevrolet Suburban
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
It makes a high pitched whine at about 62 mph
Vacume line off of transmission won't alow high gear and at that speed the tranny starts screaming for relief. Find the vucume line and make sure its good and connected at both ends
Nov 16, 2009 | 1991 Volvo 240
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Lexmark X5495 Printer Logo
134 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
