Question about Acer Aspire 3680 Laptop
When I try to use the reboot cd's that I copied from the laptop that I have. I get an error message after loading disk 4.
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    What does the error message say? How many discs are there in total? What is the make/model of the laptop?
My computer went to a blue screen and says fatal system error the initial session process terminated unexpectantly with a status of 0x00000000 (0x0000034 0x0010037c). The system shut down.
Dear Sir,
Please have the problem solved by having the system
repaired. This is actually being caused due to a corrupted
or missing system file. Please have the instructions to
having it repaired
Repairing Windows XP using CD installation
The CD installation for windows XP allow you to repair windows whenever there is file missing or corruption or improper function of Windows. This tips can be useful before you opt for a complete format to your computer.
Your first step is to boot the computer using the cd installation.
Below message will display:
Press Enter to setup Windows and accept the license agreement. Then select the XP installation you want to repair and then press R. 1wq9asrj-2-s-.png
Windows xp will copy necessary before reboot. You will be asked to press any key to boot to the CD. nzlmbj8t-2-s-.png
Do not press any key. Windows will boot to installation screen automatically and start installation.
After installation, enter the CD key (windows registration key) to finish repair.
You can now remove the cd from the cd drive and reboot the computer for appraisal
Jul 14, 2011 | Dell Inspiron 1525 Notebook
NTLDR is missing this is the message i get then it says press any key to restart when u do nothing happens
remove all the external devices plugged into your computer. and try to restart. if it does not work,
You need to have your Windows XP disk with you to resolve the problem. You just need to copy it directly from the Operating system CD. The NTLDR is responsible for loading Windows so if its is missing or damaged, there's no way you can load Windows back unless you copy it from the CD to your computer.
follow these steps:
1. insert the Windows XP disk in your computer
2.Restart your computer and press f12 to open up the boot menu
3. Select CD/DVDor ODD from the options and repeatedly tap the enter key until you see the "windows is loading files" message.
4. select the option to repair your computer (letter R)
(A command prompt will open)
5. Log into your Windows installation by pressing the "1" key and press enter.
6. You will then be prompted for your administrator password, enter that password. (leave it blank if you do not have a password)
7.type the following:
copy e:\i386\ntldr c:\ (press enter)
copy e:\i386\ntdetect.com c:\ (press enter)
(letter e corresponds to the drive letter of your CD/DVD drive, change it if you have a different letter assigned to that drive. for example: Your DVD drive is drive F, instead of typing "copy e:\i386\ntldr c:\",type "copy f:\i386\ntldr c:\")
8. after succesfully copying the files, type in exit or quit and reboot the computer and allow it to reboot normally.
Hope this helps
Jun 18, 2010 | Computers & Internet
Application error 437 - cannot read file 17274 bluesky.wmz This is first time I have tried to use the Toshiba recovery disk for my Satellite A45-S250. The installation repeatedly fails with the above error...
check the cd you are using for scratches, looks like a readom the cd error to me.
to solve:
copy cd using freeware program: imageburn,make an image of disk, burn it onto cd-r(your save-copy, legal)
try installing from copied version could work
else:
copy whole installation cd into sepearate folder and run installation from harddisk.
Jun 17, 2009 | Toshiba Satellite A45-S150 Notebook
'ntlr missing' after restart.
I have had this problem in the past and it was a virus. I had to reformat the hard driver then renstall the windows.
Feb 07, 2009 | Gateway MX3225 Notebook
COULD NOT LOAD OS - TRIED 2000 & 2003 SERVER
Reinstall OS without repairing. Sometimes people make the mistake between a choosing repair and a full reinstall. Also backup any files before doing so.
Sep 20, 2008 | Acer Altos G530 Server
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Error Message Upon booting up
go to bios and load defaults. if still same thing happens after reboot. Boot from OS cd, on windows etup page, choose "R" to run recovery console. Choose OS. Run CHKDSK /R.
Feb 16, 2008 | Compaq Evo N610C Notebook
Load Error! Press a key to reboot
If the computer after power on is checking the drives ie the CD and/or floppy to boot from then it is a software problem. You need to put in your recovery CD/disk and hope fully it will allow you to just fix the errors within the boot up files and not have to install os.
Your norton could help - try booting from that or the ones you produced by using Norton.
If you have to reload then do not format just save old - it should give you that option.
Jan 30, 2008 | Computers & Internet
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Jan 18, 2008 | ASUS A8N-SLI Deluxe Motherboard
Laptop CD/DVD Drive
In order to copy files to a CD like a hard drive you need a program that can treat the CD like a hard drive. Sometimes called *drag and drop or drag to disk*, is this what you?re using and if so what program are you using?
Mar 31, 2007 | Toshiba Satellite A105-S4004 Notebook
Acer Aspire 3680 Laptop Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
