Question about E-Machines (308714) Motherboard
EMachine T1742, T2862 & T2958 Bad Power supply, bad mootherboards
This seems to be a common problem with eMachines. The power supplies I can replace, but I would like to repair the motherboards. I would like to obtain schematics for Trigem Imperial- GL, and Intel D845GVSR motherboards and troubleshooting guide if available. I replaced the visualable bad capicators on the D845GVSR motherboard with no joy. HELP!!!
  • ottodtaylor Jan 07, 2009
    I was hoping someone, anyone would have at least one sussess story with the DREADES eMachine. Thankyou very much, I will keep looking!
    President:
  • E-Machines Master
  • 1,314 Answers
I agree with Ekse. Replacing caps is a waste of time...what's to say that the damaged caps didn't cause other damage to the motherboard. Sure, you can save a little money but as you've already found out just replacing the caps don't always work.
Posted on Jan 07, 2009
  • E-Machines Master
  • 13,433 Answers
Well this is just my take on the problem, and feel free to click on the repost button to get more opinions from people around here but.
I haven't seen a single service manual for a motherboard and when I worked at a Pc repair shop we never repaired motherboard we replaced them. So as far as I know not available but I will look into it and if your not satisfyed with my solution go ahead and click repost.
Posted on Jan 06, 2009
  • Ekse Jan 06, 2009
    I'll give you my honest opinion about this:
    The motherboard which has these issues is faulty from the factory they will all fail eventually, so you are trying to repair a product that will fail again. You would save money and time to move to another motherboard.
How to take pictures off dead emachine
The hard drive must still be working to get the pictures off. The best thing to do is remove the hard drive from the machine and use either an external USB type case to mount the drive into so you can use another computer to explore the drive or there is a tool that just plugs on to the drive with a USB cable and power supply built in that will serve the same purpose. You must get the appropriate type to match the drive type which could be either IDE or SATA. SATA drives use the small cable and IDE use the wide ribbon. If the hard drive is not working, you would have to get specialized and expensive company to retrieve the data from the drive.
Jan 14, 2014 | eMachines Emachine T1742 Power Supply...
How can you check a computer power supply. (Emachines T1742) Shouldn't you be able to do that with a volt/amp meter? Do you have to short two connector pins to simulate the computer on-off switch?
In order to turn it on if the motherboard wont do it yes, you have to short out the green and a black wire for it to turn on. Volt meter is handy to check for proper voltages: 12v, 5v, 3.3v, also should be test when the computer is under full load. It is also recommened to check for bad capictors on all computer compentents including the power supply. Usually on store bought computers the power supply starts to give out, and the caps buldge, and if its left unfixed it causes caps in other places to go out. If there are caps bulding on the power supply and/or other stuff, buy new capictors of the same voltage and same or slightly higher UF rating, I recommend Rubycon or Nichon from badcaps.net. Hope this helped.
Nov 01, 2013 | eMachines Emachine T1742 Power Supply...
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
Jul 16, 2012 | eMachines T Computers & Internet
Emachine T2958, tested power supply (good). Green
Is your PC making any beep sounds, anything at all on monitor? if nothing try removing cpu then re-install cpu?
Feb 09, 2010 | E-Machines (T2958) PC Desktop
Will not power up
This is a common problem with Emachine motherboards, the problem is the power supply is a best tech and allows voltage surges to the motherboard which fries it too. If available you usually have to replace both the power supply and motherboard. I do not know what exactly goes bad on the motherboard but I have replaced many emachine power supplies and motherboards. The motherboard kit which used to be available from Emachines included a power supply and no warranty if you didn't change the power supply. They knew they had a problem.
Dec 27, 2009 | E-Machines (308714) Motherboard
T2862 wont work -no power goes to it.
emachine?
is it new?
if its not, then check the power supply, there should be a green light on the back of the unit. if this is yellow or not lit at all then the problem is your PSU
crack the case and make sure the PSU cables are connected properly
also while your in there check for swollen capacitors or dust
Sep 04, 2009 | E-Machines eMachines Desktop PC
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
Emachine T2862
have you try to test your power supply if it actually works? try 2 remove it from your pc plug the power chord on it and short the GREEN and BLACK wires using a pin or any conductor u can use. see if it turn on lights and fan turns on when you do that.
Feb 01, 2009 | E-Machines eMachines Desktop PC
Can u possibly tell me where i might be able to download a schematic for an EMachine desktop computer model #T2742? It is out of warranty and was donated to our church and we need to know where to...
Hi dallasblue08,
Here's a diagram of what your looking for:
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
Hope this helps!
Mark
Jan 04, 2009 | Computers & Internet
Power supply
emachines t1742 comp , power supply is a 350 watt atx
Aug 19, 2008 | Computers & Internet
E-Machines (308714) Motherboard Logo
119 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
