Question about Kenmore 24032\24036 Top Load Washer
While the washer drains and spins, new water comes in
My Kenmore Elite#110.26942500 turns any cycle to heavy duty itself.
Even while the cycle is "one rinse only" the washer rinses clothes about 6 times, but each rinse takes a very short period of time. And while the washer drains and spin the water, new water comes at the same time, so the clothes are still soaked.
Manually cycles works the same way.How can I fix it?
  • Kenmore Master
  • 8,220 Answers
Drain hose must be at least 30 inchs above the floor.
Posted on Jan 06, 2009
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
check motor coupler remove motor and check plastic coupler and rubber drive coupler. when you look under machine should see residue on floor from faulty part if this is problem
Nov 21, 2008 | Kenmore 24032\24036 Top Load Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
222 people viewed this question
Sal De
fordexpert
Robert Rankin
