Question about Brother HL 1440 Laser Printer
Printer is not working.
I am trying to set up brother printer at my home.
I connected all wires.I can't figure out why printer is not working. Please help me.
thank you.
    Problem Solver:
  • 14 Answers
Your computer should pop up and tell you that you've installed a new piece of equipment anytime you plug something into the USB port, since most peripherials are plug and play. If not, then it doesn't recognize the printer. You may have a bad USB port. Try plugging the wire into a different USB port during the installation process.
With Brother, you have to use their installation CD and follow their instructions. You can't hook up the wires till *after* the CD has walked you through their installation process.
Try reinstalling using their CD and a new USB port to see if it will work now.
Posted on Jan 07, 2009
Brother DCP-195c error prinr unable 73
Sir/Madam
I suggest You Go to Official Brother Printer trouble Page For You Brother Printer Problem On Below Brother Printer forum URL Link:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000400/000095/faq000495_033.html?reg=eu&c=gb&lang=en&prod=dcp195c_all&Cat=11
I Hope You resolve Your Brother Printer Issue,
OR
In case You Need Online Assistance Then follow Us For ON:
Brother Printer Support
Feb 01, 2014 | Brother DCP 165C Compact Color Inkjet...
We just got two brother hl 2170w printers from a lab across campus, they were configured for a wireless connection and now we are trying to connect them to the network via a wired connection. the test page...
hi there, this should work for you:
When you disconnect an Ethernet cable from the printer, wireless network will be enabled.
On the other hand, when the Ethernet cable is connected to the printer, wired network is enabled.
If you press the Go button for approx. 13 seconds, the network setting page will be printed out. Then release the Go button, wired network will be switched to wireless network even if the Ethernet cable is still connected.
You can then verify your network settings and change between wired and wireless setups.
Apr 16, 2010 | Brother HL-2170W Laser Printer
Hello Expert Brother Technician 3/15/10 I
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
Click LINK= http://www.4all2sell.com/pdf/Brother-MFC-240C-Manual.pdf
You will need a adobe reader to see this file If you not got an PDF reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Brother MFC 240C All-In-One InkJet Printer
Can't figure out how to connect my printer to the "network"... hope I'm using the right terms. Had it all set up to a dlink wireless router with a modem and had to disconnect it all to resolve another...
connect a lan wire from router to printer
print printer information
find out ip
pls add static ip address on the pc(printer and pc should be in one network)
type ip address on the internet explorer
change the ip address of your router class ip network range
remove static ip from pc
Oct 28, 2009 | Brother HL-2170W Mono Laser Printer
Brother MFC Networking Problem with New Router
When you purchase a new router you must change your security settings to accept that program so it can be ran to work with your os please check your firewall settings to see if they are blocking any new router installs you can do this by selecting start-programs then go to security settings and check your network connections and settings for your security settings.
Oct 05, 2009 | Brother MFC-7820N Printer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
I have a Brother HL2070N printer. I have 2 computers and want to share the printer. I connected the printer via the USB port to Computer 1 and it prints fine. I set the printer to SHARED. Computer 1 has...
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Apr 14, 2009 | Brother Office Equipment & Supplies
Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Feb 21, 2009 | Brother MultiFunction Center MFC-440CN...
Faxing
The phone wire from your wall jack gets connected to the jack marked "line" on your printer. If you are also are connecting a separate phone to the printer connect a phone wire from the jack marked "ext" to your phone. Just in case you need a manual here is where you can download one. Please rate if this helped. Thanks. Have a nice day. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Mar 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer installation
i need a installer in my printer ( Brother DCP 130C) any can help me plz...
Mar 16, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother HL 1440 Laser Printer Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
