Question about Microsoft Windows XP Professional for PC
My Windwos XP Professional 32 bit does not suppor more than 3GB
My Window XP Professional 32 bit does not support more than 3GB DDR2
RAM. I wish to install 4GB DDR2 - 667Mhz RAM to run high end graphics, how do i go about it.
with warm regards.
Dr.Khan
  • Anonymous Mar 24, 2014
    My computer is a dell pc with a rev a00 e210882 motherboard. The computer shows under the computer properties that there is 4GB of ram installed but only 3GB usable. I looked online and the motherboard supports 4GB of ram. I checked some windows forums and they said that the boot options under msconfig could be reducing it. I checked and this was not the case. The forum also said my nividia graphics card could be sharing some ram. I looked in the resource monitor and it showed that 1GB was set to hardware reserved just as the windows forum said would be the case if the graphics card was sharing ram. The problem came up in how the forum said I should be able to change the amount hardware uses in the bios, however I cannot find this option. If you know of how to resolve this or how to change that setting a different way I would greatly appreciate it.
    Thanks,
    Phillip
    Scholar:
  • 143 Answers
Dear sir
here no matter for windows xp it's a frequience problem related to hardware here some RAM is not compatible with yr motherbord it's depend which company motherboard u have as par my sugection if u nedd to eun high end graphics why don't u in install highly configard graphic card.. it's help u.....:)
thanks
please vote
jo_Chinmay
Posted on Jan 06, 2009
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Apr 01, 2017 | ASUS Computers & Internet
RAM Only 3Gb
Err... Do you mean it has more than 3 GB and it sees only 3 GB or it has only 3 GB?
For first one: You are probably using a 32 bit operating system. For example, Windows XP 32 bit sees only 3 GB of RAM. Fix it by installing other operating system(or simply a 64 bit version). Also, linux is known to work with more than 3 GB of RAM even on 32 bit system.
Second one:
You could buy some aditional RAM, but first check which RAM type are you using(DDR, DDR2 or DDR3). Also, you should check if there are any free slots left, and does motherboard support more RAM.
Feb 18, 2014 | IBM X236 Server
W7 64 bit pro
These are the specs, but I don't see 64 Bits support. Hence it must be running 32 bit and Windows 32 Bit has a 3GB limitation. Furthermore, even if it did recognize it. Your applications must be written to utilize more RAM. For instance I have 16GB and never seen the usage go more 3GB.
http://www.asus.com/Motherboards/P5VD2X/#specifications
2 x DIMM, Max. 4 GB, DDR2 533/ Non-ECC,Un-buffered Memory
May 17, 2013 | ASUS P5VD2-X Motherboard
What kind of Pc station compact to dell 755
Hmmm, here we are again.
Between this question, and the other question you posted, are you asking what kind of Ram Memory to use?
DDR2 Sdram at 667Megahertz, or 800MHz.
That is PC2-5300, or PC2-6400.
The Maximum TOTAL Amount of Ram Memory for the motherboard, is 8GigaByte. (8GB)
This is ONLY if you are using an Operating System that is 64-bit.
(Examples; Windows XP 64-bit, Windows Vista 64-bit, Windows 7 64-bit )
Using an Operating System that is 32-bit, the realistic figure is more like 3GB to 3.5GB.
EVEN if you have 4GB of Ram Memory installed.
IF, this is not what you need meazaw, post back in a Comment.
Regards,
joecoolvette
Jul 26, 2012 | Computers & Internet
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Imedia A883. I have just bought 4x 1GB RAM to install. When I turned it on it was only reading 3GB, so we changed the ram in the slots and now the screen is not working, and we changed again, and the...
Windows XP (32 bit) can only recognise about 3GB of RAM. Windows XP (64 bit) can recognise stacks more, as can other 64-bit Operating Systems.
Sep 11, 2009 | Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Installing additonal ram
Down load you product manual and it should have explicid directions within it.
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3425&LINKTEXT=Guides%20%26%20Manua
Dec 31, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
