Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Error Code 49 on Fisher & Paykel Intuitive Eco
I have googled error 49 and it said it could be the hot or cold water valve. The hot water valve was swollen so I replaced it and my washing machine still comes up with the same error code.
Is there anything else I can do to fix the problem and I do not have an instruction manual either?
Thanks
  • ric prisk Mar 02, 2009
    i have the same problem now. the original problem started with the main board buggered and machine not turning on. once i replaced the main board and set it up, the machine run sweet for two washes then went out on a fault 49 and i have not been able to get around this. the coils tested up to the correct resistance so i swapped them to see if the fault number changed...and it did not so i am now wondering if there is a way to clear all faults and start from scratch. does any one know how to clear faults on a IW712 Fisher Paylel ???
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Posted on Jan 13, 2009
2 Suggested Answers
SOURCE: Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Intuitive Eco - code 49. What does that mean?
faulty cold water valve, if that doesnt fix it then fault computer board
Feb 27, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 49 f&p aqua smart wl80t65c
49 is a cold water valve fault. test the valve for voltage while filling, it should be recieving 24V. if not, the problem lies with the motor controller.
Aug 30, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
I have an Intuitive Eco Fisher and Paykel top loading machine. When I turn it on a continuous beeping sound comes on with the message Fault Code 49 apearing on the screen. What can I do to solve the...
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Error Code 49 Fisher and Paykel Washing Machine
the code error (49) is telling you that the inlet valve is not working make sure the hoses are not blocked. if you have fitted the valve and is still not working then i would try using the unit on cold if it still does not work then there must be a short in the p.c.b control board.
hope this helps a little more
Jul 12, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I need service code 49
Hi just read your posting.Error code 49 means your cold water valve is faulty,The valves are located under the top panel.Do you help in the step by step testing of the valves?If you do please reply and I can help you rectify this problem.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive Eco 701 ... error code 50. I'm sure it's to do with the fill solenoids. It is filling very slowly.
Yes. Whichever is filling slow. Hot or cold. It is a code for the fill valve. Just replaced the cold fill valve on my unit which seems to be the one that most commonly goes out. Easy repair. 2 screws and 1 Plug...If you unscrew the top by taking out two phillips screws in the back, you will find some paperwork about trouble codes, repairs etc...Right next to the fill valves.
Jan 24, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco code 49....
code 49 is a faulty cold water valve fault code. If you replaced both the valves, the wires and plugs to them are ok and it's still not working then you need to replace the Main Motor Controller module, there's no way to reset this fault sorry.
PLEASE "rate my solution" thank you.
Steve
Mar 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
4,398 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
