Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Icemaker not working
Icemaker broken
  • Whirlpool Master
  • 19,396 Answers
Check the water inlet located at the back of the fridge.
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
There are many problems that will prevent the ice maker from working. It could be frozen over, the inlet water valve could be inoperable, the harvest thermostat may be bad. If you can remove the ice maker, you might be able to tell what might be the problem.
Oct 13, 2014 | Whirlpool Refrigerators
Icemaker is not making ice. after reinstall, icemaker runs with no water and is not making ice. seems timer and relay are not in sinc.
remove the white cover on the icemaker may come off hard do you see a white round cam there should be no broken retainer holding it on if it is broken motor moldule is req ..... doe's it have an metal plate under the white cover if so check the cams 1 small 1 large to see if any of the teeth are broken if so replace the icemaker
Aug 19, 2009 | Kenmore Refrigerators
Icemaker don't work
Most icemakers have their own brains so to speak all they need is power, low temp, and water to work.So check the water supply to the unit and use a test cord to check the water valve. It could be not cold enough in the freezer ,check temp and shrouds etc.
once you've ruled out outside influences you've got to dismantle the unit and check microswitches and stats all the while on the lookout for something thats broken lol
May 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Bin Arm
It probably broken, these do not normally just come out. Please go to and click on the parts distributor search engine. These parts are available and this icemaker can be repaired. It's a little tricky to replace, but it can be done. Make sure to cut the power when working inside this icemaker.
Aug 31, 2008 | U-Line Icemaker
Ice maker not working
the icemaker will run at 120v ac +- 10% so 108 v is within range altho marginally. since you have the icemaker removed. remove the front cover and check to see if the drive gear is broken or if the 2 center pins that hold the gear in place are twisted or broken. this is most likely the problem. the motor module can be replace very easily part # is 8201515
the normal home position for this icemaker is at the 2:00 position facing the front of the icemaker. if it is any other position the motor module is almost always the culprit..
Dec 17, 2007 | Refrigerators
Ice maker stopped working
pull the front cover off of the icemaker and see if the drive gear is broken (there are 2 tabs in the center of the gear make sure these arent twisted or broken as well) if so replace the module on the fron of the icemaker. if that checks fine check for frozen fill line..
Dec 16, 2007 | Refrigerators
No ice
if you remove the icemaker there is a white cover over the head of the icemaker, pull the cover off. youll see a gear in the center. in the middle of that gear there are two plastic tabs that hold it in place one or both of the tabs may be broken cause a bad conection behind the wheel. if tabs are broken you need a icemaker modual (part the gear is attatched to) if not broken you need a watervalve located on the bottom right side behind the freezer
Nov 19, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore side-by-side fridge icemaker
yes. replace the icemaker modual and your problem is solved
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
194 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
