Question about NEC MobilePro 780 Pocket PC
NEC MobilePro 780 Screen
My Nec MobilePro worked for a while, until, after about two minutes, the screen went blank. Whenever I hold down the brightness button the screen works. What is wrong?
A couple of things spring to mind. Have a good hard look at the screen when it goes dark. Is there still an image there but it is really dark? If so, consider that it may be a faulty backlight. It may also be a faulty ribbon cable joining the screen to the main unit, or it may be that the brightness down button is stuck and causing it to lower the brightness. The fact that you are pressing the brighness (up button I am guessing) and it comes back on, may indicate the bright down button is stuck or by pure chance you are pressurising the board in that area causing a bad contact to work, such as power to the backlight or pressure on the ribbon cable. I dont have one of these MobilePro's but I am just going on things I have seen with notebook PC repairs. Hope this helps.
Posted on May 25, 2007
Linux on nec 780 - how to install
There are no Linux distributions for this device, and there is no reliable method to install once.
Nov 27, 2010 | NEC MobilePro 780 Pocket PC
Nec Mobile Pro 900c stuck
do a hard reset by removing the backup battery and main batteries. replug them and hold the power button for 10 seconds
Dec 30, 2007 | NEC MobilePro 900 Handheld
NEC Mobilepro 900c will not connect w/computer
Are you using the NEC Mobilepro 900c drivers? I'm sure the drivers are different. YOu can find the XP drivers here: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip In addition, you should make sure that you have Activesync 3.8 or older. You can find it here: http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Dec 25, 2007 | NEC MobilePro 900c Pocket PC
Windows ce and memory cards
MobliePro 780 can use up to 32mb of memory and not 16mb but but you can't get any higher cause its limited by Windows CE Memory Map. If nec will offer an upgrade for windows CE3 or higher problem could be solved.
Sep 19, 2005 | NEC MobilePro 780 Pocket PC
Windows ce networking
Well your going to have to check whether your device has inbuilt wireless capability (refer to manual). If it doesnt there are various expansion slot solutions like SD and Compact flash wireless cards.
Sep 15, 2005 | NEC MobilePro 780 Pocket PC
PowerPoint with an external monitor
A video driver update has been released to resolve that issue. Contact Technical Support at 800-632-4525 to request the file MP780-Display.exe from the password download section.
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Windows NT server using RDP client
To resolve this issue download the MobilePro Service Pack 1 and install it on your system: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp
Service Pack 1
NEC Computers has developed a service pack to address several service issues with MobilePro 780 and 880 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 780 and 880 systems immediately by installing this service pack according to the installation instructions. * Download Service Pack One for MobilePro 780 and 880: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Installation * See Contents of Service Pack: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#FAQ Installation Instructions for Service Pack One for MobilePro 780 and 880 First download the service pack (MP78_UPDATE.CAB) to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP78_UPDATE.CAB file, follow these steps: 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Full (hard) reset on your MobilePro. Caution: Performing a Full reset erases all your data. Your MobilePro resets to the factory default settings. Please perform the backup first or you will lose data! 3. Copy the MP78_UPDATE.CAB file to you MobilePro desktop. 4. Install the service pack by double tapping the MP78_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. The following Message box will be displayed: Warning !!! 1. In order to ensure these patches are properly installed you must perform a Hard Reset prior to the installation. 2. You must back up all application and data files before performing a Hard Reset. The Hard Reset WILL ERASE all applications and data stored on this Mobile Device. 3. This file must be installed immediately after performing a Hard Reset on the Mobile Device (before any applications are reinstalled). 4. Press CANCEL to exit. Or Press CONTINUE to install this file. 6. Press Continue to install the service pack or Cancel to back up your data. 7. When the Setup Finish message box is displayed, Click Ok. This will remove all temporary files from your systems. 8. When the Setup Complete message box is displayed, click Ok. 9. Perform a Soft reset on your MobilePro. 10. Optionally, restore your MobilePro data using the ActiveSync restore procedure. 11. Once the service pack is installed, NECC recommends that you use the ActiveSync b
Service Pack
Sep 14, 2005 | NEC MobilePro 880
NEC MobilePro 780 Pocket PC Logo
292 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
