Question about Lenovo 3000 C200 Notebook
Lenovo laptop - windows will not start, how do go safe mode?
Goes to windows start-up, then it goes black w uth no key response
is there anyway to reset?
  • ypavank Mar 31, 2009
    Nope. I have the same problem. it doesnt show even safe mode menu when i press F8. any help pls
  • David Brenchley May 11, 2010
    reboot - when OS begins load press f8 -- select safe mode -
    does it boot?
  • 117 Answers
You have a hard drive failure. i suggest you take the drive out. if you can. attach it to a usb to sata if possible and run a diskchk and before you do that you can backup docs to the machine you got it attached to. If you are not getting a windows option in anyway shape or form you have a hard drive failure which is why it does not give you any options.
Good Luck!
Posted on Jul 20, 2009
Safe mode in lennovo g500
When you start your computer. Hit the F8 key, and then a prompt will come up to boot in Safe Mode, Safe Mode with Networking, and Safe Mode in Command Prompt. Make your choice.
Apr 08, 2014 | Lenovo Essential G500 Laptop Computer -...
My laptop Lenovo g400.when I turn on my laptop its functioning but after 3 hours or less iturn off my laptop but when I I turn on again there is no screen display its all black but the power led is and...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 09, 2013 | Lenovo 3000 Computers & Internet
Os is working but i could see only black screen after i switch on my laptop?
First i will suggest you to restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files and fix registry and windows errors which causing black screen
Jul 05, 2013 | Lenovo b560 Notebook
Startup screen wont show on external display
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
you could select the safe mode option and see if you can get the extended desktop again but first you will have to find out why it crashed
if you select last known good configuration that worked it might give you an idea
hope it helps
Apr 17, 2012 | Lenovo G560 - 15.6 - 500GB - Black -...
I lost my initial log in password, how do I bypass/change it.
Hi tamuscott...
1. Keep pressing "F8" as the laptop computer starts.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me
Aug 29, 2011 | IBM Lenovo ThinkPad SL410 2842K3U Notebook...
My Lenovo laptop starts up and shows Microsoft Windows starting to load but a few seconds later the screen goes black. The computer is on but it shows a black screen.
Try running in Safe mode.
Start the computer and hit the F8 key many times till you get Windows Advanced Option menu - Choose safe mode with or with out networking.
Does your computer seem to be working now? (safe mode is a limited use mode)
Chances are that your computer is infected and preventing normal use..
Restoring the computer would be the easiest way to fully clean out all infections and needed software corruptions. A full restore DELETES all DATA from the hard drive - Make sure you have all your data backed up. You can back up your DATA in side safe mode.
The information given relates to CORRUPTIBLE software like a virus....
Other issues may factor in to this but, not believed to be so.
Thank you for contacting
Nov 11, 2010 | Computers & Internet
It starts with the lenovo screen and then goes to the Windows XP screen but it goes back to the Lenovo screen. What can I do so I wont have to restore my system again?
ok, press f8 key as the system is booting up, this will put you in safe mode,
if the system boots okay goto command prompt mode and type chkdsk /r to repair any files etc ,
Try booting up again, if the problem is the same then it a startup file that need repairing so goto safe mode, command prompt type bootcfg etc and try repairting it that way, us e the help command to point you in the right direction.
Oct 01, 2009 | Lenovo 3000 C200 Notebook
Laptop in continual stop start cycle
please the memory RAM with the same type and specifications.
Sep 24, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Black screen nothing loading
One of your driver is acting up. start in safe mode, disable one of the drivers (DVD or whatever) then close and try to start normally. If the PC starts then reinstall the driver.
Aug 10, 2009 | Lenovo 3000 C200 Notebook
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Lenovo 3000 C200 Notebook Logo
3,030 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
