Question about Everex gPC2 TC2512 VIA C7-D 1.5GHz 512MB DDR2 80GB VIA UniChrome Pro Linux gOS V2 PC Desktop
Enlightenment error in trash
When i open my trash enlightenment error SEGV'd
appears and i do not have any idea what to do
  • 31 Answers
Delete it
Posted on Jan 07, 2009
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
How to delete emails from ipad mini ?
Open Mail Inbox, you have to touch Modify first, Trash will appear.
Aug 01, 2014 | Apple iPad Tablets & eReaders
How delete incoming message on iPad
Open the email. Click on the file folder icon top right. Menu will appear on left. Tap on trash. This will move to to the trash.
Jul 17, 2014 | Apple iPad 32 GB WiFi Tablet PC
What is mac error code-8003
If you are a Mac user then I know you have experienced this. You've been deleting files and your Trash Can is showing that there are items in it. You try to empty the trash and all of a sudden an error window appears. It probably looks something like this.
I share a link please visit and read it.
http://www.easypctutorials.com/how-to-fix-error-code-8003-os-x/
Thanks,
Apple Support
May 11, 2014 | Computers & Internet
We have a parity error on our ThinkCentre S51 Desktop. What is this and how do we rectify this issue?
A RAM parity error? Just tell it (in the BIOS settings) that you don't have memory with parity installed, or replace the memory with that kind. You probably had to replace the BIOS battery and the setting defaulted to DDR with parity bits somehow.
There's serial communications parity too...mostly deprecated by USB, but it can come up in connecting POS (point of sale) printers, etc.
If the error instead arises in another context; well, you'd need to search for some enlightenment relating to that and 'parity' to get some enlightenment on the subject.
Jul 09, 2011 | IBM ThinkCentre S51 Intel Desktop PC -...
Cannot open the application,move it from the Trash.
This error message only appears when you are trying to run an application that is currently located in the trash. Try dragging the application out of the trash and onto the desktop, then open it.
Dec 16, 2010 | Apple 24" iMac Desktop
What is error code 43 for AMC 5 on a mac?
Mac Error Code 43 occurs due to wrong OS Configuration or due to wrong installation. To Fix Mac Error Code 43, just read the easy steps are given below:
Easy Steps to Fix Mac Error Code 43
Step 1: Reset PRAM Settings
    ·First shut down your Mac computer.
    ·Meanwhile Mac is shutting down you need to prepare for pressing command+option+P+R keys all together.
    ·Now turn on your Mac and press command+option+P+R command before the screen with grey start-up appear.
    ·At this point of time hold all these keys until you hear a start-up sound for three times and then release all the keys. Step 2: Delete All Locked Files
    ·You need to navigate to Applications then open utilities and click on terminal.
    ·Now open the terminal and type chflags -R nouchg command on it.
    ·Now find at the bottom dock and double click on the Trash icon.
    ·Press command+A to select all the files in the trash folder.
    ·However, in case of you not able to find the terminal window, arrange finder window, so that you can see at least a part of terminal window.
    ·If you have done then press Return key on the terminal and empty the trash folder.
    After following these steps if you are unable to Fix Mac Error Code 43, then just dial our toll free Mac Technical Support Number 1-833-493-0111 and get instant help.
1 833 493 0111 How to Fix Mac Error Code 43 on Mac OS
Aug 19, 2010 | Avid Media Composer 3 Upgrade Version for...
Epson Stylus printer is connected, but will not print! Error message says: Error: /Library/Printers/EPSON/InkjetPrinter2/Filter/rastertoescpll.app/Contents/MacOS/rastertoescpll failed Have tried several...
Found this on the Web. If you find helpful, pls rate me.
Here is the link for all the discussions regarding this error.
http://discussions.apple.com/thread.jspa?threadID=2199441
Welcome to Apple Discussions
Go to: Apple > System Preferences > Print & Fax > Print and reselect your printer in the Default printer: box near the bottom of the panel. Then next in the same Print & Fax preference panel, select Open Print Queue: and Delete all the Jobs in the Status box and try printing something again.
reply
have no idea exactly what that error means, but now I suspect that when you "Trashed the EPSON folder in HD\Library\Printers\Epson" you trashed an important part of the OS X and not the installed Epson software.
If you have a backup Time Machine, a backup clone or that file is still in the trash you need to restore it "HD/Library/Printers/Epson/InkjetPrinters2 or whatever" back to the correct location, run Repair Permissions and hope that fixes it. If not then backup all your files, because it seems like you may have to completely reinstall the OS X....
Good Luck.....
Mar 03, 2010 | Epson Stylus CX4200 All-In-One InkJet...
F drive error Ox80070052
Reboot. Open Windows Explorer (Win key + E). Insert drive. Does F or any other drive become available?
Jan 03, 2010 | HP Computers & Internet
Stuck Trash Compactor
I can't get to the rear of the compactor. How do I get the front off to get to the rest of it?
Mar 14, 2008 | Dishwashers
Everex gPC2 TC2512 VIA C7-D 1.5GHz 512MB DDR2 80GB VIA UniChrome Pro Linux gOS V2 PC Desktop Logo
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
