Question about Tivoli (PAL) AM/FM Radio
Antenna on radio broke
I have a Tivoli AM/FM Pal radio and want to purchase a replacement antenna because my reception is compromised with only half an antenna.
  • 509 Answers
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Posted on Aug 21, 2009
Amazon has replacement antennas for Tivoli
Posted on Jul 17, 2010
    Sergeant:
  • 431 Answers
Replace with new antenna or attach a long wire with it
Posted on Jan 08, 2009
Transformer to old PAL Tivoli been eaten by rats. Where to find another for this old model
Try radio shack in States, Maplin in the UKand other similar retailers elsewhere. Also, if you can identify it try ebay, they carry a lot of these parts
May 30, 2015 | Tivoli (PAL) AM/FM Radio
Pal speaker
you should read the catalogue.
Mar 18, 2013 | Tivoli (PAL) AM/FM Radio
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
I have a Tivoli Ipal and I have a broken antenna. I have a new replacement antenna but need to install it. help.
Bought a replacement antenna for my iPal for about $5 plus a couple of dollars shipping. Installed it in 5 minutes without taking the back off of the radio. No big deal. Simple, cheap, fast.
Jan 20, 2011 | Tivoli iPAL AM/FM Radio
Can't seem to tune many stations at all. Also once a station is tunned it "slips".
The antenna works with the power cord. Try extending the length of its power cord with an extension cord.
Position of the radio in the room, the furniture in the room and your position in relation to the radio all affect its reception.
If there is a place to connect an external antenna, this will be helpful. Check with Radio shack and best buy for a FM loop antenna. Usually the wire is flat.
An inexpensive antenna for FM only is also a cheap alternative
Jan 03, 2011 | Tivoli Model Three Clock Radio
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
Tivoli Model One Radio Humming only, no reception
The fuse would cause a total absence of power. Your problem is likely a blown filter capacitor in the power supply. Unless you have electrical/electronic skills, the radio will require professional repair.
Oct 10, 2009 | Tivoli Kloss Model One AM/FM Radio
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
Tivoli iPal
send it back! I have had 2 fail this way.
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Tivoli (PAL) AM/FM Radio Logo
2,462 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Willem.
Willem.
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
