Question about Samsung OKIDATA - OKI Microline 590 Printer
Not getting ink from cartridge to paper, i believe my gap settings are messed up.
Besides the fact i can barely read the print, now it ink doesn't even seem like it's hitting the paper.
  • Ellen Volk May 25, 2007
    thanks a lot. i understand what you are saying. can i add to this and also ask if there is a way i can adjust the print head? the numbers and letters are hard to make out. (this is besides the ink not making contact).
    Novelist:
    Champion:
  • 254 Answers
A few possibilities here: One, is your ribbon cartridge dried out (essentially out of ink)? Dot Matrix printers aren't near as common now, and if your cartridge has been in the retailer's stock for years, then it could indeed be dried out. Another, the ribbon isn't being advanced, or spooled. The ribbon is spooled as the head carriage moves back and forth. If it isn't being spooled, the ink in the spot over the printhead will be quickly depleted. A no-spooling condition is usually caused by a problem in the cartridge itself. Also, make sure the cartridge is properly seated in the holder. If it isn't, the drive spindle isn't fitting up into the cartridge properly, and might not actually drive the mechanism inside the cartridge. Lastly, if your cartridge is dry, they can be reinked if you can find someone with the reinker to do it. I once did ribbon reinking with a Macinker as a side business, and someone in your area might have one of those rigs. Otherwise, just buy a new cartridge, and hopefully it will be reasonably fresh, with good ink.
Posted on May 25, 2007
You guys have been a great help. when i get back to use the printer, i will try your suggestion. thanks again!!! i love this site!!! ellen
Posted on May 26, 2007
    Scholar:
  • 77 Answers
All of dodgechargers items are valid, however, there this a setting on your printer called the printhead gap adjustment setting. This is to compensate for the thickness of multipart forms. You should have it set to 1. On most Oki printers this is a blue lever just to the left of the print cartridge. I could read 1,3,5 or 1,2,3,4,5. If there is not a blue lever there, look on the right or left of the platen (paper roller) for settings similar to this. It adjusts the distance from the printhead to paper. If you're using a single part form, and have it set too high, the distance from the printhead to paper will be to great and you will not get an adequate striking force. Between dodgecharge and me I guarantee we have your problem solved. Ed
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
My printer was working perfect. I was printing paper and when i went to print another document the printer read," Remove and check right cartridge". I did this. I cleaned it, checked for...
clean also the Ink cartridge connection (contacts at back of ink cartridge) including its pair contact to printer (located in the ink cartridge holder)..... Goodluck!!!
Mar 02, 2011 | Office Equipment & Supplies
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Can print the color I want. Only prints red.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Ink cartridge reset.
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Apr 29, 2009 | Lexmark X2650 All-In-One InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink system failure Oxc19a0031 I have an HP842C. The ink cartridges appear to be full, and in fact I have changed them for new ones, but I barely get a print, It is sometimes enough to make out (barely)...
Clean the cartridges.
Go to Printers/Faxes from your START Menu
Select the printer
Select Set Printer Properties
Select the Services Tab
Clean them - I had to do it 5 times and take out the black cartridge and shake it really good until ink started coming out and clean it again. I primed 3 times.
Worked for me.
Sep 29, 2008 | HP DeskJet 842c InkJet Printer
Samsung OKIDATA - OKI Microline 590 Printer Logo
104 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
