Question about Linksys WRT54G2 Wireless Router
Ethernet connection problems!
I have gone through the set up and once I reach the final step it says that my ethernet cable is not installed when all my cables are connected to the correct places firmly. How do I fix this problem? Can I?
  • ashley_blais Jan 06, 2009
    does it make a difference if it is a mac?
  • Anonymous Jan 16, 2009
    I CARNT HELP U BUT HAVING SAME PROBLEM MYSELF HELP HELP HELP
  • Linksys Master
  • 4,338 Answers
Router setup
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 06, 2009
  • JDTec
    JDTec Jan 06, 2009
    No it works the same.
  • JDTec
    JDTec Jan 06, 2009
    Make sure that the Mac is set to obtain an IP automatically,in your network connections under preferences.
    Once you get online with the network cable , you can the unhook the cable and get online wirelessly with your Airport.
    Good Luck,
    Joe
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
Modem light is blank on motorola wr850g, how do i fix?
If the modem light is not turning ON,
1) check if the modem is ON
2) check if the ethernet connection is properly made
3) check if the port on the modem is working, confirm it by connecting it straight to the computer.
4) check if the ethernet cable is working fine.
5) Then try power cycling the router. Unplug the power cable and connect in back after 20-30 secs.
6) Then try pressing and holding the reset for 20 secs.
7) Finally connect a single ethernet cable from any LAN port to WAN port and check if the modem light is ON.
Ultimately, if even after this step, if the light doesn't turn up, either the modem LED would have gone bad or the WAN part of the router would have gone bad.
For further clarifications, revert!
Thanks for asking,
Regards,
Arvind S Iyer
Sep 29, 2010 | Arris WR850G Router (DHWR850G)
I cant connect to the internet
How to quickly install and use your Belkin wireless G router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
How to change password
1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
I have a wireless router i can get it working right?
How to quickly install and use your wireless router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 26, 2010 | Airlink AR430W Wireless Router
I need to enter my code
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 23, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Linksys WRT160N will not finish installing. On the 4th step it says your ethernet cable does not appear to be connected properly. Error 321. I don't really think its the ethernet cables because i tried 2...
error 321 or 322shows that the cable is not connected to the router and the computer.
That is actually a bug in the CD. Even if the cable is connected it shows that it is not connected.
You can set up the router manually, without the CD.
Click Here for step by step solution
Nov 03, 2009 | Linksys WRT160N Wireless Router
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
May 14, 2008 | Linksys Wireless-B Broadband Router Retail...
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Linksys WRT54G2 Wireless Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
