Question about Microsoft Zune JS8-00001 Digital Media Player
The receiver for my headphones in my 8GB Zune doesn't work
So the receiver in the zune doesn't work. I tried some suggestions from people that had the same problem and it worked for a while. But now the left headphone doesn't work at all. Part of the receiver broke off a little bit when i put my headphones back in...so i dont know what i should do or what to buy to fix it, but if someone could help that would be awesome.
    Problem Solver:
  • 11 Answers
Wo, wo ,.wo what do you mean the receiver? the headphone plug in? if thats the case then it better be under warranty because ms will charge about 160 so ive been told. It will have to be repaired by MS
Posted on Feb 14, 2009
How can i update zune hd
How to update your Zune player
Overview
If you haven't used your Zune player in a while, you might need to update it in order to get the latest features and improvements.
Steps to update
  1. On your computer, start the Zune software.
  2. Connect your Zune player to your computer by using the USB cable that was included with your player.
  3. If a newer version of the Zune firmware is available, you'll see a notice to update your player. You can also manually check for new player updates in the Zune software. Go to Settings (located at the top of the screen), Device (located in the upper-left corner), and then Update (located in the list at the left).
  4. If you receive a notice to update your player, follow the on-screen instructions. Important During the update process, don't disconnect your Zune player it until the update finishes. The update might take several minutes. During this time, your Zune player might restart several times.
Mar 31, 2015 | Microsoft Zune 30 Gb Digital Media Player...
I recently intalled new Zune software for Vista, but my Zune player does not synchronize with my system.
If it doesn't connect, I suggest uninstalling and reinstalling the Zune software.
Try to use a different USB port you haven't used before, so Vista will reinstall the USB drivers for the specific port.
If that doesn't work, with the Zune in, go to Device Manager and uninstall and reinstall the drivers that are installed for in the DM.
Jun 11, 2011 | Computers & Internet
8GB Zune Mp3, Wont Sync
Go To the Zune site and get the Zune software to do that.
Jan 04, 2010 | Microsoft Zune JS8-00001 Digital Media...
I have a zune 120 mb. It shows it is playing a
First off. i think you mean 120gb.
Secondly, Here are just a few different suggestions.
1) Make sure its not muted on your zune
2) Some headphones have a volume switch on them so if yours have that switch, turn them up.
3) Try a different pair of headphones.
Nov 02, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
8gb zune ''back'' button does not work
the set needs to be oped and have switches checked, one of the switch is holding down a connection of power.
also check the reguration of that set,
pause switch is cascaded in series with the many switch.
plse try that
Mar 18, 2009 | Microsoft Zune JS8-00001 Digital Media...
DELETING MUSIC FILE FROM ZUNE MP3 8GB PLAYER
go to zune program program,right click the song(s) and go to delete
Jan 13, 2009 | Microsoft Zune JS8-00001 Digital Media...
Backlight doesn't come on
if the back light is not coming on then the backlight is eather bad or is not getting power from the circuit board.
Dec 31, 2008 | Microsoft Zune 2nd Generation Digital...
Can i hook a surround sound to my zune
It is usually as simple as getting a 3.5mm stereo headphone jack to RCA adapter, like this one:
http://www.radioshack.com/product/index.jsp?productId=3359117 (this will work just fine, even though it says 'ipod')
Or they have "Zune Ready" adapter kits, like this one:
http://www.radioshack.com/product/index.jsp?productId=3004031
Once you have the cable, you stick the headphone plug (3.5 mm stereo mini-phono) into the headphone jack on your Zune, then you insert the red and white RCA jacks into an open input on your surround receiver... most have an auxilliary input jack set on the front of the unit. All you need to do at this point is select the "aux input" for the source on the surround receiver, start your Zune, and make sure the volume on the Zune is somewhere in the 50 - 75% range, and you should be good to go.
Dec 08, 2008 | JVC THD-50 System
The headphone interior cable does not work.
Hey Kathyywatty,
The problem you're encountering may not necessarily be a loose internal connection, and may instead be a defective headphone jack. In cases when headphones are unable to make a secure connection, users may only experience sound coming from one of their headphone's speakers, a static-filled signal or no sound at all.
While there may be some third-party parts suppliers that carry replacement components you can install on your own, I'd strongly suggest contacting either the toll-free Zune support hotline or your local repair facility for further assistance. Any repairs that are not performed by a factory-authorized technician may void any warranty coverage you still have on your Zune.
If you're not sure how to contact Microsoft, you should be able to reach their technical support by calling 1-877-GET-ZUNE (877-438-3269). Additionally, if you're not quite sure where your local repair facility is, you may always bring your product into the Geek Squad® counter at your local Best Buy™ store for service and support.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
75 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
