Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
Dishwasher is not cleaning dishes.
The dishwasher is filling up just below the black coil. I do not think the water is reaching the arms to shoot up and wash the dishes. Water drains fine from the dishwasher to the sink. I also do not think the arms are turning when the machine is on. Also, cycle stops at 5 o'clock. Need to manually adjust to continue. Soap dispenser is fine. Please advise.
  • msalarcon Jan 08, 2009
    Thank you for the quick response. The unit still wouldnt move to the next cycle after 2 hours. The water was hot and and I ended up burning my finger on the heating coil! I dont think enough water is filling up in the unit.
  • 318 Answers
You need to check to see what the temps of you water going into the unit is. it needs to be atleast 120 degrees. if not your unit may be waiting to heat the water, until it does then it wont go into the next cycle. it could be the heat cycle is not working so that would cause the unit to not advance.
let the unit run thru the place you think its stopping, but not more then 2 hours. if its not advancing then you might have a bad heating element.
Posted on Jan 06, 2009
  • Tom Zwiebel
    Tom Zwiebel Jan 08, 2009
    im really sorry about your finger. the proper amount of water in your unit is to fill just below the heating element. what might be happening is the pump screen may be clogged with food and junk causing the motor to not spray any water around inside your unit.
    if it doesnt spray the water then it wont heat the water properly causing the unit to think its not heating and then cause a longer then normal cycle.
    take the lower wash arm out and then the pump covers and look in the bottom of the pump to see if the screens are plugged. clean them if needed. it may also be the motor is not running or the pump impeller is stripped out. so when you find out more, just let me know and i will try to help out.
Sears dishwasher not cleaning
You may have a bad pump, or the pump intake (inside the bottom tray, under the dish racks) may be clogged with crud from years of dirty dishes.
Jul 31, 2014 | Kenmore km 665.15765692 3376066 Det Latch,...
I have a Frigidaire dishwasher, PLD4460. Only 4 years old. The dishes on the top rack are not coming clean anymore. Something as simple as left small bits of broccoli do not even get rinsed out of the...
Hi
If the top rack of the dishwasher doesn't get clean, check your appliance to see if you can fix the problem.
First check the spray Arms to make sure the holes in the spray arms are free and clear of debris. Your dishwasher should have several spray arms, including one at the bottom of the tub, one under the top rack, and possibly a third spray arm on the top of the tub. Sometimes food and mineral deposits can block holes in the spray arms, preventing water from spraying effectively. If this occurs, warm some white vinegar and pour it into a spray bottle. Spray the holes with the vinegar and dislodge debris with a toothpick or large safety pin.
Then check to see if your dishwasher has clogged filters. Filters generally cover the drain valve area to catch debris as the water drains from the dishwasher. Many dishwashers have maintenance-free filters, but your dishwasher may have filters that need cleaning. Read your owner's manual before you perform any filter maintenance to avoid damaging your dishwasher.
Check your water temperature to make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not be hot enough to clean dishes effectively. Turn your kitchen hot water tap on and wait until the water warms up completely. Fill a cup and measure the water temperature with a kitchen thermometer. If the water is less than 120 degrees Fahrenheit, turn your water heater up to 120 degrees.
Load the top rack properly. Place cups and bowls upside down in the rack and don't nest dishes because this can prevent water from reaching dishes. Don't overload the top rack. Instead, position each item so the dirty areas of the dishes will receive full contact with water spraying up from the main spray arm located beneath the top rack. Prevent items from hanging below the top rack, which could prevent the spray arm from rotating.
Also check this link for more helpful info:-
http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 15, 2011 | Dishwashers
Dishwasher will fill up with water but wont clean dishes.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
Dishes aren't cleaning. Filling with water, rinsing then draining, refilling with water -- hot, soap released. When dishes come out, barely clean. Used to work like a charm... Thoughts?
Hi
Feb 16, 2011 | Miele 23 in. Novotronic G841 Built-In...
Not cleaning well
Hi
Feb 13, 2011 | Maytag Dishwasher
Top rack won't clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Sep 20, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishes are not clean.. on top level the dishes seem to be steamy
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jan 30, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Spinning arms stationary
problem is usually debris in the end angled jet of the spray arm which is used to turn the arms. take them outy and patiently clean. very common problem
Apr 24, 2007 | Neff 24 in. S4443 Built-in Dishwasher
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
193 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
