Question about Samsung Digimax S800 Digital Camera
Beeping sound I cannot turn my camera off. It beeps and the screen goes blank.
  • Nancy Babineaux May 25, 2007
    Taking the battery out did not help. The camera lens is still open and I cannot turn off the camera for the lens to retract.
Take the battery out wait a minute and put the battery back in again....
Posted on May 25, 2007
SOURCE:
Hear beeping sound..
Go to
http://support.lenovo.com/en_US/diagnose-and-fix/detail.page?DocID=HT035729
it explains each beeping sound secuence, what it means, etc. Hope helps
Apr 05, 2014 | Lenovo Computers & Internet
MY GT5654 desktop pc.makes a beeping sound when i turn it on.and get a blank screen.what is wrong with it?
you proberly got BAD RAM.kurt if just a upgrade did you get the right RAM.if not a upgrade videocard maybe.infomation is essential to little information.
Apr 11, 2013 | Gateway GT5654 Desktop PC
My camera makes a beeping noise EVERY time I push a button on it! It's really annoying! How do I turn the beeping noise off???
Tap MENU to bring up the menu screen. Tap the wrench tab to access the Setup menu. Scroll down if needed, and select "Sound Settings." Turn off the "Button Sound" and, if desired, the "Shutter Sound."
This is described in the "Sound Settings" subsection of the "Setup Menu" section of the manual (page 148 in my copy).
Apr 13, 2011 | Nikon Coolpix S4000 Digital Camera
My ASPIRE M5641 desktop cannot start, it only displays a blank screen there is not even a beeping sound when I turn it on, is it damaged or something? before it turns like this I've read in the screen in...
check on your RAM memory whether is loose or not, try to remove the RAM memory and insert it back again. After this is done,t he beeping sound will gone and yr desktop may start.
Nov 18, 2010 | Acer Aspire M5641 PC Desktop
Power on screen blank.. fan on
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. You can disassemble or remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion dv6704nr Notebook
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
C2Solutions
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
My camera isnt working
if the picture turns all white, then you might have a problem with the screen.
-or your're just aiming it at a bright object. (try covering the lens with your hand- dont actually touch it, just block out the light and if the screen goes dark then its still working)
if some sand or grit got inside your camera, then you have a serious problem, as sand is very abrasive,and could damage the internal mechnisims.
you should seek professional help on getting the inside cleaned out.
May 03, 2008 | Olympus FE-190 Digital Camera
Beeping noise and blank screen
The beeps are part of the POST (Power On Self-Test). Here's a link to the Lenovo site that might help you interpret the beeps you're hearing:
http://www-307.ibm.com/pc/support/site.wss/MIGR-46018.html
Good luck.
Nov 19, 2007 | IBM ThinkPad T30 2366 Notebook
Canon ixus 400
throw it and a new one a bit more modern.
Aug 20, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Samsung Digimax S800 Digital Camera Logo
66 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
