Question about GPS
We received a Garmin 760 for Christmas, used it once and the second time we used it the audio never worked again.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Have you checked to see the following:
    1. Is the audio muted? Is it selected to mute?
    2. Is the volume turned all the way down?
    3. Is the audio output set to FM? If FM, you will only hear sound through your car stereo.
    - Jim
    SHARCNET-USA
  • 4 Answers
First thing I'd do is check you voice & speaker settings. If they are in order try a reboot. Be advised this will erase all existing data, routes etc.
Posted on Jan 07, 2009
Garmin nuvi 760 map update free download
Garmin Express Garmin Express but it probably won't be free. $50 for one time or $90 for lifetime... dont get the lifetime, get a new unit instead.
Jul 29, 2014 | Garmin Nuvi 760 Car GPS Receiver
Garmin won't come on
plug it in to the wall charger or car charger for about 4 hours, then slide and hold power button for up to 15 seconds till it starts.
if that fails, unplug the nuvi then press and hold the lower right hand corner of the screen until you see the message " Do you really want to erase all user data?" remove your finger from the screen and select YES. (this will erase all your saved data) this should reset your nuvi to the factory settings.
use the web updater to update your nuvi once you get it started again.
you can get it HERE
let me know if you need further help.
bill
Sep 05, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I cannot register online; tells me that my serial number is invalid
Call Garmin
My 760 had an error in the serial number. The garmin tech solved this in seconds with the corrected number.
Harvey
Apr 28, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Won't switch on
I had a similar situation. My 760 could not be switched on, despite a fully charged battery. The hard reset procedure (power button held for 8 seconds) fixed my problem.
Apr 07, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin/honda nuvi 760
The unit receives signals from 3 (or more) satellites, and uses very sensitive timing to determine your distance from each of them. The unit does not transmit to the satellites, but only receives what they transmit... so it is a "receiver, only".
See here for the details of how a GPS works:
http://electronics.howstuffworks.com/gadgets/travel/gps.htm
Hope that helps you...
Feb 13, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 wont come on
Try holding the power slide to the left and holding it there for 8 seconds. If that doesn't work, try charging it via your PC & USB cable. If that doesn't work, try a mains charger if you have one (I had to do this with mine). Good luck!
Dec 31, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
How do I down load music and audio books for garmin nuvi 760?
you need to load your memory card with all the music and audio books and insert it into your garmin then follow on screen instructions
Dec 12, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 - No Voice Directions
Check The system settings, I had to download the newest version of the audio software for the voice to work. The software vanished once and I had to re-download it using the web updater.
Hopefully it will stick around this time.
When I load the new software the voice works.
Sep 03, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
