Question about Texas Instruments TI-30XA Calculator
How do you replace the batteries
How do you replace the body
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 100,387 Answers
Use a small Phillips screwdriver to open the back of the case.
Posted on Feb 05, 2010
2004 gmc envoy.. just had Battery replaced and needed 2sensors. Since then my radio, hear, power doors, car alarm arent working. fuses were all checked .. everything's good.
Check or replace the battery to body ground wire. 3 main grounds are battery to engine, battery to body and engine to body.
Mar 11, 2016 | GMC Cars & Trucks
Were is the main ground wire from the engine to the body on a 99 chevy malibu
From the engine to the body? Or from the battery to the body? Assentially, when the battery is connected, the whole car is a ground strap. If you are replacing the negative battery terminal, then run it to the nearest piece of metal, with the shortest amount of ground strapping.
Aug 29, 2014 | 1999 Chevrolet Malibu
Model 7501 wont turn on
check your ground from battery to body, then you may have to replace the selinoid next to battery , about a foot up the hot side
May 25, 2012 | Taylor & Digital Scale Lithium Scale
Recently i replaced battery in my 2002 envoy, now if a/c is on it idles rough and will stall, can you help me with solving this problem
Clean your throttle body. Disconnect the battery, and take the plastic resonator and large hoses off that attach to the throttle body. Clean with throttle body cleaner, must be nice and shiny. When finished, drive around for 20 min or so, so the computer can re-learn the properly functioning throttle body. Your computer learned some bad habits with the dirty throttle body, so when you disconnect the battery and reconnect it, it thinks the throttle body is clean and functioning properly which is not the case. If you do it yourself, can cost you a can of throttle body cleaner $7.
Feb 19, 2011 | 2002 GMC Envoy
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
How do I know if the battery needs to be replaced?
mcdevito75 here, Generally if the unit slows down or just isn"t as efficient as it was, then it could be time to change the battery.
Jun 22, 2010 | Conair TH402 Thinner Digital Body Fat &...
I changed battery on car now power door locks stop working. I've check the fuse and replace, but they still are not working, What elese can I check?
If they worked before u changed the battery check and see if u hooked up the body ground or if is broke loose from the body. It could go from negative of battery to the body or from the block to the body
Aug 09, 2009 | Kia Sorento Cars & Trucks
Nikon Cool Pix 7900 Battery door won't stay closes
There are plastic clips on the battery door and body of the camera that lock the door in place. If they are broken of the battery door the door can be changed. If the clips on the body are broken the camera as a rule is history. Replacing a camera body is not a feasible repair.
Jul 02, 2009 | Cameras
Texas Instruments TI-30XA Calculator Logo
54 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
