Dealership has to replace key for newer vechicles from 1994 up to 2012 .all vechicle ignition keys has a transponder consist of a resonator and ic circuit which includes a processor and non volatile memory embedded into the key or remote transmitter.the ignition key is read through ignition switch to the immobilizer and ECM.THE IGNITION KEY IS PROGRAMMED. back in the 50s 60s 70s 80s and early 90s hardware store could make new cars keys but now car keys has program chips has to replaced at dealership.
Just take it to your local lowes or home depot
SOURCE: I have a 2007 Dodge Caliber 2.0 automatic. My wont
the stering wheel has a loke that can interfer with the barrell. so make shore that the steering wheel is not jamed in lock posistion by terning it to a senter position
SOURCE: i have a 2011 dodge
P0700 DODGE - Transaxle Control System Malfunction
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Driveability problems
- Transaxle shifting problems
Possible causes
- Shorted or open circuit within transmission control module (TCM)
- Failure of transaxle control module
Tech notes
Since the P0700 is just and informative code, check the TCM for more codes to resolve the problem.
P0700 DODGE Description
The transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. When the TCM detects a malfunction with the control, a signal is send to the Engine Control Module (ECM) to trigger the Engine Light or Service Engine Soon light. The ECM stores the P0700 code and it means the TCM detected a malfunction with the transaxle controls.
CLEAR THE CODES AND SEE IF IT RESETS. MOST LIKELY NOT A PROBLEM
