Question about HP LaserJet 1300 Printer
Color cartridge stuck
How do I get a color cartridge out of the wrong cartride slot?
    Sergeant:
  • 287 Answers
PULL AND THEN CLEAN THE SLOT WITH RUBBING ALCOHOL TO GET THE COLOR OFF THE BLACK SIDE. REMEMBER TO UNPLUG WHILE CLEANING. THEN CLEAN THE CARTRIDGE WITH ALCOHOL TOO. THEN PUT BACK IN RIGHT PLACE AND YOU SHOULD BE GOOD TO GO. IT MAY TAKE SOME FORCE TO GET IT OUT. BUT REALLY NO CHOICE NOW. HAPPY NEW YEAR TO YOU.
Posted on Jan 06, 2009
Why it can't print?
It won't print if your ink cartridge is empty. Check the black and white and also the color cartrides by doing the following:
1. Slide your hand underneath the front cover and open up the case.
2. Find your ink cartrides usually located on the left on the inside of the casing.
3. Gently pull up (usually) on the cartridge and take it out and shake it. You will know if it is empty or full when you shake it. If the color is full but the black and white is out that is probably the problem. Many printers won't work if the black and white cartridge is empty because that's usually the primary color.
4. Go to Walgreen's or a similiar store and purchase a new cartridge and then just reverse the steps putting it back in. Make sure you take note where each cartride is located when taking them out and put them in their correct position when you put them back in.
This should solve your problem and you should be printing again in no time flat!
Dec 22, 2010 | Epson Stylus Photo R390 InkJet Printer
C 3180 hp printer, just bought from thrift store, ----but,,,it seems the thing that holds the ink cartridges is stuck, though its trying to slide as it should, it seems to be hitting,jamming , light re;...
First of all, if the ink cartridges are stuck, as you rightly guessed, it may not be the correct cartridge.
Now, even suppose, it is the correct cartridge, it would not have been installed correctly . the Label side of the cartridge should face upwards, Not towards you.. when you are inserting the ink cartridge.
if you are from India the compatible ink cartridge would be HP 850(BLACK) AND HP 855(COLOR)
In North,South America it is HP 92(BLACK) AND HP 93.
Aug 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
Receive msg: "Print Cartridge(s) missing or not detected
i thing u have problem with your cartride try to buy orgnal cartride and try if not then you have to go to work shop becoz u r cartride slot if not working properly
Apr 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
Color is terrible, even with new color cartridges. Black & white prints out with "stripes" across the page. Almost EVERYTHING we print is illegible. Our printer is less than 1 year old, and we have ...
remove the cartrides, clean the printer head with cotton ear bud soaked in after shave (use only a mild men after shave) the after shave has a low content of alchol.
If the printer head is built in the cartride then clean the head of the cartridge, if the print head is printer based you may have to open the front pannel of the printer to access the printer head to clean it using the same method.
Dec 07, 2009 | Office Equipment & Supplies
I put the cartride in the wrong spot how do i get it out.
Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
Pull the print cartridge toward you out of its slot.
If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector
Regards,
Jeep Brainy
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Even though I have install the ink cartride
Hi there please try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
HP LaserJet 1300 Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
