Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Drainout procedure incomplete
My machine is now 5 yrs old and has functioned perfectly all it's life. Over the last 3-4 months, it has been refusing to fully pump-out, leaving around 1.5 to 2 litres of water in the bowl, which submerges the element and the load therefore remains wet. we had a serviceman call. he pumped it out using the diagnostic functions check; he then checked the hoses for blocking or kinking, but no problem exists. he then suggested the drain hose was too high; (it had worked perfectly beforehand;) but we lowered it by about 30mm as he required. The lower drawer does not have a similar problem. I have thoroughly cleaned the filters; even swapped the impellors from one bowl to another, but not had any success. I phoned F & P in NZ to try and access the diagnostic procedures, but they would not help; suggested we call in serviceman again; very expensive! Is there a timer which controls how long the pump operates? or, is the pump-out function governed by a sensor? We do not get any error codes, just this annoying excess of water remaining in the bowl. The owners handbook states that any excess water must be soaked up manually; I have done this on several occasions, but the problem will not go away. Please advise what else I can do?
  • Michael Empson Jun 06, 2007
    Sorry I was a bit late compiling my answer. These dishwashers comprise 2 drawers, upper and lower; the upper unit is the largest of the pair. The pumps used in each are identical, so I have swapped the rotors over to see if one is more efficient than the other, but no improvement shows. Each pump has an external stator; it is of a 6-pole motor and is an integral part of the bowl. It is controlled by an on-board computer, which makes it difficult to 'liven-up' and test as a unit. The pump does function OK but appears not to run long enough while the final drain-out cycle takes place. My query is to either find an adjustment time for the pumpout cycle, or to manually pump out the bowl so the drying element is allowed to get hot enough to dry the load. Footnote; When we lowered the drainhose loop by 30mm, there was a slight noticeable improvement, but the original installation was as per F&P instructions. If it had have been incorrect, why did it fonction OK for the first 4 years?
WOW! I have the same problem with my top Drawer. I have been draining the water manually by suction, now all I do is hit the power button and then hit the start button. The drain function starts and completely drains the Drawer. Thanks for the tip!
Posted on Jul 31, 2007
I have the same problem with my top Drawer. To drain the water manually without having to suction it out, this is what I do. I hit the power button and then hit the start button. The drain function starts and completely drains the Drawer. I hit the power button again to shut it down before the fill cycle starts. I think the problem is the timer shutting down the pump too early. I don't want to spend the $$ on a service call until I know they will fix the problem the 1st time.
Posted on Jun 25, 2007
  • 883 Answers
Please clarify "The lower drawer does not have a similar problem." did the "but we lowered it by about 30mm as he required." make any difference? run this test: disconnect power to the unit. then find and disconnect the drain pump's wires (or connector). then apply power to the pump (I am assuming you have a 115VAC house supply) by a separate wire cord. run the pump on this cord until you see all the water pump out. if it does, then your timer is shutting down the pump too early. the water level sensor is mostly used for the other case during water fill only.
Posted on May 25, 2007
My LG F1247TD5 washing machine has no power only 5 yrs old last month
first check the power supply to the plug in the wall, you may just have a dead machine.
Dec 21, 2014 | LG Washing Machines
Tip
Your rights under customer warrenty
if the unit is less then 3 yrs old then it comes under expected to last warranty this law says that items above $100 u.s must last more than 3 yrs if they dont the company must give you a replacement if not fixabe or a money back refund this is law demand your right just say 3 year expected life warranty and see the look on there face it always makes me laugh at people who buy extended warranty's in this case the dept of consumer service has got your back <br /><br /><br />best of luck <br />
on Dec 31, 2010 | Televison & Video
I have a string of 20 batteries on an MGE Galaxy 3000. 3 of the cells tested bad on the last PM. The batteries are 3.5 years old and operate within the temperature limits suggested by the manufacturer....
It depends on the manufacturing battery life time. Generally they are 3 to 5 years or 5 to 7 years or 8-10 years. Nevertheless due to high cost of batteries most client opt for use 3 to 5 year life time. A simple internet search will give you the specification and from there you can decide what to do. If it is 3 to 5 years life time it is advisable to change the whole set. Otherwise you can replace the 3 batteries as a temporary solution. However it is most likely that after 3 to 6 months you will have some other bad cells.
Jan 19, 2011 | MGE Galaxy 3000 UPS System
Ours is 2 yrs old.TV turns off by itself every 2-3 min.
U replaced the projection lamp the last 2 years?U used the tv on and watches 4 or 5 hours a day?Yes,the tv projection lamp life is over.Require changing a new projection lamp.
Aug 03, 2010 | Hitachi UltraVision 60VF820 TV
Battery Life is VERY short. refuses to last longer than 10 minutes on its lowest power setting. Why is this happening? Does this happen with them all?
No generally Sony VAIO battery should last upto 1.5-2 hrs ..So your battery needs to be replaced ...
Thank You..
Dec 03, 2009 | Sony VAIO VGN-N250E/B Notebook
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
18 year-old ICF-2010 comes to life, then dies...?
Hi Tony! Have you solved the problems? If not drop me an email at.... poikaa@yahoo.com
Rod KB8DNS
Jan 05, 2009 | Sony ICF-2010 AM/FM/SW Radio
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Hi, at the moment my panafax UF-770 is printing a report for every transmission. I want to stop that, so that it only prints a report if the fax did not go through and the monthly or so report. I cannot...
To change the communications journal settings:
Press:
Function
7
Set
12
Set
1= off
2=always
3= incomplete only
Once you have chosen 1,2, or 3, hit Set
Hit STOP to exit programming mode.
This model only stores the last 100 transactions (sent or received faxes).
To print the last 100 transactions:
Press:
Function
6
Set
The machine will return to an idle / ready state when printing has completed.
Apr 07, 2008 | Office Equipment & Supplies
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
375 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Simon Flummox
Simon Flummox
Jose Pino
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
