Question about Kenmore 24032\24036 Top Load Washer
Water keeps flowing does not stop---does not go thru cycles
Water keeps flowing-does not stop when machine is on.
Does not go thru cycles--unable to operate wash cycle, except for a couple of minutes.Spin and Rinse cycle work.
Have just installed new motor coupling and new water inlet valve.
  • hyabi Jan 06, 2009
    Many Thanks to THEMOBILIAN........
    You were right on the money!!!!! I moved the tube from where it was being pinched, blew it out a couple of times, and all problems were fixed.....everything is hunky-dory.
    Thanks again........Hyabi
  • Kenmore Master
  • 8,220 Answers
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
Posted on Jan 06, 2009
  • Dan Webster
    Dan Webster Jan 06, 2009
    Blow out the tube and reconnect it tight. Drain the tub before retry.
My whirlpool washing machine wont stop filling with water after the wash cycle
your post is vauge
does it over flow
you mean it wont stop the rinse cycle
did you check it for a reset
do a factory reset
the machine will fill with water until the flow sensor and level has filled
so check and clean the machine
i find a couple of dishwasher cleaner tabs thru it first will clean all the flows and pipes and use a 60 deg long wash for whites
i think all the electro is aok so must be dirt
Sep 24, 2014 | Whirlpool Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
I have a Hoshizaki Model KM500MAE that keeps freezing up. What can I do to stop this problem
several things cause freeze ups.
If you have water filters on the water system, be sure they are not restricting the water flow. water flow pressure should not go below 20 psi.
The bin stat may not be shutting off the unit properly. It should shut off machine within 10 seconds of ice making contact.
Make sure the float switch is not dirty. Be careful when cleaning. Fragile
Make sure water pump runs the entire time it is in the freeze cycle.
Be sure the evaps are clean. Ice cubes will hang on if not clean.
Water solenoid has a screen where the water line screws on to it. Turn off water and check screen to be sure it is clean. This can restrict water flow.
Make sure water valve closes all the way. Turn machine off and see if water is still running. Valve may be leaking water thru.
Dip switches on the board, #1 and #2. Turn them both on and it will change the defrost time to 3 minutes. If both are off, they are set on 1 minute.
Hope this solves your problem. Let me know
Apr 07, 2010 | Hoshizaki Freezer Commercial Ice Machines...
After the spin cycle, the machine stops. Now and
Yes very easy the problem is the water inlet valve. There is a video at www.appliancehelponline.com/servicemanual.html that walks you thru testing and replacing on a similar model.
Mar 05, 2010 | Maytag Washing Machines
Cold water does not stop at set levels. Too much flow.
Blockage in pressure bottle or small hole in pressure bottle tube.
Feb 25, 2010 | Washing Machines
KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Jul 12, 2009 | Hoshizaki Freezer Commercial Ice Machines...
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Jan 07, 2009 | Asko W6661 Front Load Washer
Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
103 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
